HP cptoh-0603
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    HP cptoh-0603
    Good morning gentlemen...
    Picked up this TV,story from owner was that they where watching it,then a loud "pop" and screen went black,it came back on right away but colors etc where "not the same as before"...
    I searched for a "popped" component but didn't see anything so far,wondering if the "pop" was through the speakers...
    I measured the va and vs and 5 volts and they are dead on....
    Any suggestion on where to focus on??
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
  • capkid
    • Oct 2010
    • 1339
    Re: HP cptoh-0603
    I would say that your Z-Sustain is bad. The pop was most likely an IPM failure under one of the large heat sinks. Check the fuses on each sustain to confirm.
    LG Plasma Mal-Discharge Correction Service
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Re: HP cptoh-0603
      That would be good news,cause I have a Z board here in a parts TV
      Fuses on Y-sus are ok,can't find fuses on Z board.
      Going to swap the Z-sus out and see what happens
      • capkid
        • Oct 2010
        • 1339
        Re: HP cptoh-0603
        Check the Z-bias voltage on the Z-Sustain; voltage is checked across the R111 resistor. This particular Z-Sus may not have ceramic main fuses.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Re: HP cptoh-0603
          Is it me or is the site extremely slow loading right now???
          SUCCESS......!!!!! Swapped out the Z-sus board and Tv now works like a charm...
          Awesome,I'm all proud now,haha....The fame that I'm going to enjoy in my household for fixing it will be unsurpassed,lol
          Thank you very much capkid,awesome help as usual
          Do I need to adjust voltage on boards now with different Z-sus???? Picture seems perfectly fine,no dot's or sparkles etc...
          • capkid
            • Oct 2010
            • 1339
            Re: HP cptoh-0603
            Nice. Don't let the fame go to your head; remember where you came from - LOL. If the picture looks fine, I'd check and note the voltages, but you most likely won't need to make any adjustments.
            Yes, the site is very slow today.
            Edit: For future reference, when a plasma screen has a faint picture like yours, it's usually the Z-Sus in LG-based TVs.
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Re: HP cptoh-0603
              Ya,great learning curve here.....I didn't mention it in this post,but I had already swapped out the Y-buffers from my donor TV just to find out and learn what it looks like if you have bad Y-buffers,lol....Now I know that my donor TV also has a bad Y-buffer besides the bad Y-sus board(classic flickering and ticking sound on IPM)(money tight right now but plan on replacing those IPM's and fix the Y-buffer soon on the donor TV,to learn and rake in more fame for being "TV smart",lol)
              Collecting TV's like mad at the moment,it's starting to pay off in the sense of starting to have a nice collection of parts
              Hate that most I pick up have broken screens....
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                Re: HP cptoh-0603
                small question about this tv...
                There is one pixel that flickers kinda red at all times,more noticable when that part of the screen is dark..its only the one rest of screen is perfect..
                Is that a dead pixel or a sign that voltage is a bit too high..???
                • capkid
                  • Oct 2010
                  • 1339
                  Re: HP cptoh-0603
                  It's most likely a bad pixel. I had a Toshiba 50" (probably the same LG panel) that did the same thing.
                  Edit: I kind of remember trying to run some patterns onscreen to un-stick the pixel, but that didn't work.
                    Re: HP cptoh-0603
                    If you have a mal-discharging single pixel, I'd turn down the VsetUP control, or, if available, the Vset voltage.
                      Surface Mount Fuses Fundamentals Datasheet
                      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                      10-07-2024, 06:07 AM
                      How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                      by sam_sam_sam
                      About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                      Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                      12-14-2023, 07:45 PM
                    • AdrenalinTL
                      Macbook Pro A1707 - Dead - Battery 'popped'
                      by AdrenalinTL
                      Hi Peeps.
                      Just a quick question please as I am by no means an Apple fundi at all.
                      Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                      Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                      Don't want to go buy a battery for no reason.
                      Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                      07-18-2024, 09:52 AM
                    • acedogblast
                      Power supply for main amp blows fuses after replacing filter caps.
                      by acedogblast
                      Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                      I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                      I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                      02-27-2023, 05:11 PM
                    • Sik_6ty_Sixx
                      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                      by Sik_6ty_Sixx
                      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                      02-18-2025, 05:06 AM
