Samsung Model HP-R4272V/XXA 42in Plasma screen flickers
    replied
    Re: Samsung Model HP-R4272V/XXA 42in Plasma screen flickers
    If the picture is not flickering, it is rare for the STK IPM to be bad. It looks like you may have at the very least a bad upper buffer, but possibly the lower one is bad too.
  • high-tech
    replied
    I still think I got YMAIN/YSUS issues as well, I think that STK type chip under that big heat sink got issues they always go out on the LG hybrid boards but those are easy to check, you just start unplugging till the power board stops cycling
  • high-tech
    replied
    Ok I got half the screen but its all messed up, here is a pic of the set with the upper buffer removed... The TV is upside down in the picture
  • high-tech
    replied
    I'll try that, lets see what happens...
    replied
    The manual is wrong, a bad buffer can sometimes cause that symptom.
    The buffers on these sets are notorious for going bad, and sometimes taking the Y-main with them.
    You can try with only the top or bottom buffer and see if the set shows half a picture.
  • high-tech
    replied
    I did the drag the test lead across the buffer connections to the screen. and on the upper buffer board I found most of the pins leading to the top chip are shorted to ground, I know that this buffer is bad but I thought when a buffer is bad just a part of the screen is gone??? That is what the troubleshooting section of the manual says.
  • high-tech
    replied
    Ok I'll try the camera shopping...
    I replaced the bad cap, it was a 100mf 50v, that didn't fix it and made no changes. Maybe just another problem getting ready to go at a later time. So while I had the boards out I took pictures. the cap that was bloated in the lower left corner by the little transformer. the one just above the big blue poly mylar cap.
    replied
    OK...
    For reference, I purchased a high quality Samsung 14MP digital camera capable of close macro shots for £35.00 (approx $50US) from a local second hand shop, if you're looking for a new camera go down there and ask to try them out, bring a laptop motherboard or something down and you'll often find a good compact with good macro capability.
  • high-tech
    replied
    Whoops I stand beside myself, while looking at the many screws needed to be remove I found a bloated cap on the YMAIN/YSUS board ;} go figure. so I'll pull the board and replace the cap and look around @ the circuit it's in... And I'll post up results.
  • high-tech
    replied
    I give up I 'm just gonna give the customer back this tv and I can't fix it... I'm sorry for wasting your time. I won't ever ask again OK I do'nt wanna disassemble the whole tv just to show you pics of the boards, my camera sucks. I can't make out half of what I take so with that in mind the pictures aren't that functional. If I could take the kind of pics you need to see that would be one thing but like I said the camera sucks
    replied
    OK, can you get a picture of the buffer boards and the Y-main?
  • high-tech
    replied
    all the voltages fluctuate a little a few volts but no I don't have to reset a fault by cycling the power or unplugging ect. The screen will flash as long as I leave it powered on.
    replied
    No cycling as it flashes?
  • high-tech
    replied
    Alright I put the boards back in and found VSCAN and it is -198. So what's next?
    so all the voltages are ok
    replied
    Vscan = -Vsc and Vset are testpoints on the topmost board.
  • high-tech
    replied
    I had to remove them in order to get a good pic
    replied
    VSC is on the Y-main/Y-sus board.
  • high-tech
    replied
    Evidently I got a bad meter, strange readings. I pulled out my spare meter and all the voltages are close to the panel sticker.
    Panel sticker says VA 70v VSC-190v VS 201v VA 84v VSET 195v
    My meter says VA 70v VS 201v VA 87v VSET 199v
    I can't find the VSC to test???
    replied
    Can I see a picture of each sub board?
  • high-tech
    replied
    My secondary findings are still the same... the voltages coming off the sub power board to each SUS board on the VS pins is not the same. the main YSUS board is higher than the XSUS board
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • Chrissygizmo
    samsung galaxy ao2s very temperamental after screen replaced
    by Chrissygizmo
    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
    Ive eventually managed to get it on and working but it's very temperamental...
    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
    05-26-2024, 12:05 AM
  • Kiberge
    Samsung LH82QENELGC/EN Help needed - Static line on screen
    by Kiberge
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
    04-22-2024, 11:28 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Samunggg
    Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
    by Samunggg
    I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
    I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
    09-06-2023, 06:39 PM
