ps42d5s picture problem help
Re: ps42d5s picture problem help
Probably a digital board problem. Try this test.
https://www.badcaps.net/forum/showpo...61&postcount=2Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Did you see any faint test patterns, or the same images as before?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you show me how you did the test pattern jumper, may be different for this older model.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, it sounds like you have a control board fault (that board there.) I'd try replacing that. The dim image may also be caused by a bad X-main, or the control board being bad, however the noise can only really be caused by that board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by doorzonHi all,
hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
See attached picture.
I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
However, this could also be related...-
08-12-2023, 02:36 AM -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by retrorepairHello gurus, hope you can assist me...
I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
Thanks in advance.2 Photos -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by KYBOSHHello all
I pick this up free as a repair project for the holidays.
The original symptom was power cycling after 3-4 seconds with a single red light flash.
To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side... - Loading...
