37PFL7662D picture not all there
  • wreksta
    • Aug 2013
    • 508
    • england
    I have a philips in to repair
    it comes on picture is like this sorry I have no cam but you get the idea
    the bottom black bit is still lit up though any help tom
    Re: 37PFL7662D picture not all there
    Probably has 720p main board in when it uses 1080p panel. You can change panel setting from the service menu. Check the chassis label for the option codes, and refer to the service documentation to adjust.
    • wreksta
      • Aug 2013
      • 508
      • england
      where can I get service doc mate
        Chassis # on back of set e.g. L523.UA AA?
        • wreksta
          • Aug 2013
          • 508
          • england
          thanks tom was that but now get this
          any thoughts
            You have a bad LCD panel - tab bonds. May be fixable.
            http://www.youtube.com/watch?v=mMo3N...ature=youtu.be
            I don't understand though, you did not have this problem before?
            • wreksta
              • Aug 2013
              • 508
              • england
              it did but though it was rectified not to worry ill strip it again
              • Patrick501
                Philips 55PUS6704 no picture, backlight ok
                by Patrick501
                I'd like to repair a Philips 55PUS6704.
                It turns on and you can see the backlight, hear the sound but no picture.
                When I disconnect one of the T-con cables, half of the screen turns white.
                right cable disconnected= right side white
                left cable disconnected= left side white
                When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                Also you can notice one single...
                11-12-2025, 08:46 AM
              • Rauni
                Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                by Rauni
                Hello, this is my first post on this forum, and my first attempted to repair a TV.
                My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                Read also that we should test what happens if we...
                10-01-2023, 12:06 AM
              • Schwoin
                Philips 243v5lhsb00 Monitor Picture too bright
                by Schwoin
                Hey everyone,
                the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                you can see them on the top half of the photo.
                At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                03-21-2023, 12:40 PM
              • madyoyo
                Philips 37pfl560: Yellow picture
                by madyoyo
                HI.
                I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                05-30-2025, 10:16 AM
              • charlesdutcher
                No picture issue in Philips Chassis FTL2.1
                by charlesdutcher
                My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                Is there someone having any symptom like this? How to fix it?
                Thanks in advance!​
                08-06-2024, 09:55 PM
