Sharp 3LS36 - partial vertical collapse from bad C509
  • japlytic
    • Oct 2005
    • 2086
    Today, I got a Sharp 3LS36 TV which had the problem of a partial vertical collapse where only a third of the screen can be filled with a picture.
    So I tried replacing capacitors C501 (with a tantalum unit), C503, C506, and C509 in the Vertical section, and measured the originals with my handy capacitor tester.
    Upon measuring the original 1000uF 10V unit (Nichicon VX Series) which was used in position C509, I got an off the scale reading (even at the highest range of up to 20,000uF) on my capacitor tester, which showed that this capacitor was defective, even though the others I mentioned earlier are probably still good.
    C509 was upgraded to a 16V unit as a good measure since the main power rail used by the vertical output stage is 10.7V.
    As a good measure, C615 was replaced with a low-ESR unit, along with C705, and the following capacitor upgrades were also done:
    C701: 1000uF 25V (originally 100uF)
    C704: 1000uF 16V (originally 330uF)
    C623 and C624: 10uF 160V
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Sharp 3LS36 - partial vertical collapse from bad C509
    The bad nichicon wasn't bulged was it?
    Yeah I have heard before the capacitance can increase sometimes when the capacitor fails.
    Poor 'nichi ... that shows that all capacitors are the same, in this respect - they all can fail, even the good ones
    Muh-soggy-knee
    • japlytic
      • Oct 2005
      • 2086
      This capacitor had no visible signs of being bad - you are certainly right about even the best electrolytics are not immune from failure.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        VX is an 85*C capacitor, that's probably why it failed in that application...
        Some are worse than others (more aqueuous ones may expand more with exposure to heat but it also depends on the other additives used in the electrolyte and the quality of the inhibitors), but I suppose the quality does vary even in the Japanese supply chain... I would not fault Nichicon. I think the only vaguely similar capacitors that can really take excessive heat (besides non-aqueous lytics maybe, assuming that the heat is not of discolorating range) are functional or solid polymers.
        • ninja_zx11
          Sharp LC-70LE650U vertical black and red bars
          by ninja_zx11
          70" LED TV is Sharp LC-70LE650U.
          Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
          07-07-2023, 11:27 PM
        • valvashon
          Sharp LC19SB24U; red vertical line comes and goes
          by valvashon
          Yes, this is a very old Sharp 19" but I would like to fix it if possible. As you can see from the attached picture there is a single red vertical line.
          Yesterday when I turned the set on, it was there for about 30 minutes then disappeared and did not show up again (set was on for another 3 hours or so).
          Today it was not there when I powered the set on, then appeared after about 15 minutes. Set has been on for about an hour and it's still there.
          From what I have read I'm guessing that this might be the t-con board and not the display itself as it does come and go.
          02-03-2023, 10:02 AM
          Acer Aspire A111-31-C509 Notebook 1 Specification for Upgrade or Repair
          This specification for the Acer Aspire A111-31-C509 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A111-31-C509 boardview and A111-31-C509 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 11:39 AM
        • lowteq
          Partial Success Repairing Vertical White Bands on HP Z30i
          by lowteq
          Hello.
          I was given a HP Z30i LCD computer monitor that had several white wide vertical bands on it. I had another Z30i that was working and after a lot of swapping of components I found that the logic board, TCON board and associated ribbon cables were healthy. The problem was the ribbon cables that go from a long slender PCB across the top of the panel onto the panel itself. The problem connection was on the PCB side not the glass panel side. These ribbon cables are attached with some kind of heat set adhesive.
          I'm aware that this type of problem usually isn't repairable...
          03-27-2020, 10:49 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          Yesterday, 03:15 AM
