Do you Have This
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Do you Have This
    Help for Model of may TCL MODEL-19E9B
    I nee Schematic Diagram
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: Do you Have This
    Up...
      Schematic of WHAT?
      Main board, power supply, inverter...?
      How about part #s of each... almost certainly TCL did not make this themselves but someone else did it for them.
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • reessi
        Imac A1312 - Blown Diode, Need Inverter Schematic?
        by reessi
        iMac 27-Inch "Core i7" 3.4 (Mid-2011):
        First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
        Searched all over for one!
        All voltages to the Inverter are correct:
        (12v in, 3.3v Enable and PWM Approx 3.0v).
        Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
        After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct...
        12-04-2020, 06:58 AM
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        Today, 12:34 PM
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
      • atunguyd
        Acer x163w Monitor PSU schematic
        by atunguyd
        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
        03-05-2025, 02:08 PM
