Sylvania LC420SS8 Power Supply Troubleshooting
  • gravitronic
    • Aug 2013
    Hi Badcappers!
    I've got this LCD TV in my garage from a friend. It stopped working and has no signs of life. I found this forum via a google search for the service manual for this model, which is in this thread:
    https://www.badcaps.net/forum/showthread.php?t=24445
    I can fix digital electronics relatively easily but this is the first power supply I've tackled, so I'm looking for help.
    The TV shows no signs of life, but no capacitors appear bad from visual inspection.
    Some voltages during standby:
    'ALL 3.3v/5v' at J107: 3.29
    KEY1: 3.26
    KEY2: 0
    'for 5v' at J142: 6.57
    PROTECT2: 0.9
    PROTECT1: 0.09
    None of those voltages change when I press the 'power' button.
    Can anyone help? Thanks!
  • gravitronic
    • Aug 2013
    Re: Sylvania LC420SS8 Power Supply Troubleshooting
    Just read enough of the service manual to realize all my debugging of the power board while disconnected from the digital board is totally invalid. Will reconnect those tomorrow and debug from scratch
    • aasnowskate
      • 118
      • usa
      I have the same model TV with the same problem. Please post your findings.
      Thanks in advance.
      • brnrubbr
        • Jun 2013
        • 37
        Have you guys had any luck? I just got a no-power LC420SS8. I have got the Backlights working, but the TV eventually shuts off.
        Status: Backlights on, "Digital Television" text, regular flashing green ON light, then a very quick flashing green light and TV turns off.
        I suspect power supply and will troubleshoot tomorrow.
        • brnrubbr
          • Jun 2013
          • 37
          Main board was the cause for my TV. Not too expensive, but I could not find exact circuit cause.
          • zvaniel4o
            • Feb 2014
            • 12
            • US
            Was there any success after you did that?
            • zvaniel4o
              • Feb 2014
              • 12
              • US
              It was not the main board with mine... it was faulty smt and tht diodes... replaced - works like charm!
                03-31-2024, 02:12 PM
              • dragon3x
                >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                by dragon3x
                Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                that is still quite new, as it worked OK for some months until it failed.
                At the time I was not into power supply electronics; it was put
                aside and a new power supply installed inside the computer. Also at the time
                power supplies were half the price of today's.
                On the PCB there are a D339 and 7500B chips.
                I have found that schematics with these 2 chips (see included file).
                Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                Some measurements,...
                06-05-2024, 03:34 PM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Zippie
                Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
                by Zippie
                I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
                Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
                During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
                Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
                Opening the PSU the only things visible initially...
                03-07-2024, 07:58 PM
