LG 42PJ350N completely blown Y-SUS
  • PowerAmpFreak
    • 982
    • Sweden
    WOW! Checked a "clicking LG" today and the Y-SUS was completely blown.
    Nearly all power semiconductors had gone into heaven.
    As a power electronics designer, I begin to wonder what these guys are doing in terms of "circuit protection". Common sense tells that a failure in one stage should be isolated and won't take other stages with it in the dark.
    Appearently these guys are not paid to provide this kind of protection, probably module swap is the only solution these days.
    Re: LG 42PJ350N completely blown Y-SUS
    What semis failed? LG label them. If for example the SUS UP FET failed (connect output to VSUS) then the SUS DN could fail too... but the ER UP/DN and the RAMP UP/DN should survive, because they're rarely active and they don't have direct paths for the SUS voltage to go.
    Quite a common problem is the firmware, which controls the FETs, can go bad or crash, causing an anomalous condition. Or, the firmware doesn't include any method for detecting a fault, leading it to continue to operate, damaging more stuff.
    • Vesku
      • Oct 2013
      • FIN
      SYS_UP's and SYS_DN's shorted on my case. I can't find anything else wrong on the board with a quick look.
      I ordered new FET's, but just wondering has anyone else had a go, did the FET's help or is there some underlying issue that causes the failure in the 1st place?
      • PlasMatt
        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
        by PlasMatt
        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
        09-20-2025, 06:50 PM
      • cmlewis89
        LG 47LB5DF blown power supply board
        by cmlewis89
        Hi folks,
        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
        09-03-2024, 07:50 PM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • legg
        LG 42PC3 buffer output doesn't follow YSUS
        by legg
        LG42PC3D -UD originally with green lamp but no display or audio.
        Owner says was working, then went 'pop'.
        All 5V caps bulging. replaced.
        All PSU output voltages within spec but -Vy is low on YSUS.
        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
        eventually shorts DG. Replaced all 3 - -Vy now OK.
        Y scan buffer test point does not follow YSUS output below -50V
        Note: This unit seems to expect YSUS output to park at -Vy in between
        drive signal pattern periods. A replacement drive signal board confirms this....
        11-18-2021, 11:49 AM
      • swerg
        Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
        by swerg
        Hey everyone,
        I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
        I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
        I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
        06-06-2024, 03:39 PM
