I have a 2009 Sony KDL-32L5000 LCD tv that i use mostly as a computer monitor. A few days ago it developed a weird inverted ghost image that flickers and is present in both input signals and the tv's on screen menu. It was originally present for about two days then went away for a day and returned. It seems funny to me that the ghost image is inverted vertically. I am thinking its the T-Con board, but would like a second opinion.
sony kdl-32l5000
Re: sony kdl-32l5000
The kdl-32l4000 version suffers from tab bond issues:
https://www.badcaps.net/forum/showth...hlight=32l4000
https://www.badcaps.net/forum/showth...hlight=32l4000Comment
Ah, didn't pay close enough attention to the inverted image. I wonder if you have a main board problem. Main board and panel issues are common in Sonys when they fail, so I'd suspect one or the other.Last edited by capkid; 08-08-2013, 05:21 PM.Comment
Both effects can be caused by tab bonds. Inverted picture on its own sometimes can be caused by tab bonds on some panels -- not sure how but it is a known, fairly uncommon issue.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The t-con would be cheapest part to replace, so I might give it a shot.Comment
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
by rex98hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
maybe you could help me how to shift these resistors to disable its onboard ram.
this is is the presents and not presents... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
by LINCKODEHello!
I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
- Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
- Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
- Bad image detail/sharpness
These issues switch between each other from time to time.
After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am... - Loading...
