Grunding plasma( 42v7)
  • willyam1
    • Feb 2012
    • 112
    • israel
    Hi to all
    this tv came with no screen problem
    found in YSUS 6871QYH45D 4A FUSE IS OPEN and the big ic IPM YPDD-JO14C IS short
    I order 2 ipm from UTSOURCE IN HONKONG
    replace the ipm and the fuse operet it its the same problem
    voltage measured VS=184V VA 65V VSCAN=114V VY=-85 15V AND 5V
    THER 3 OUTPUY FROM YSUS TU YDRIVE upper and lower -30v 108v -30v also ican see in the scope that ther is a pulses in the output but not sure if they are corect also ther pulses in the flat cabel from logic board to ysus
    in the ZSUS OUTPUT ALSO PULSES CAN SEEN ON THE SCOPE AND 80V DC IS MESUERED
    AFTER A FEW MINUTES IM TOUCHING WITH MY HAND AT THE COOLING IPM IN THE ZSUS AND ITS STARTED TO BE HOT BUT IN THE YSUS IS COOL NOT WARMING
    COULD BE THAT THE IPM THAT I BOUGHT IS FAKE OR THER IS ANOTHER PROBLEM?
    WILLYAM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
  • Truncatedhose
    Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
    by Truncatedhose
    Greetings all!
    Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
    Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
    07-04-2018, 10:59 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • Salvatore057
    plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
    by Salvatore057
    I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
    Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
    I am lost, should I change the YSUS board? Is the YSUS board damaging...
    04-29-2018, 01:29 PM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
