Lg 50pk550
  • kmoonen
    • Dec 2011
    • 61
    Lg 50pk550
    Hi Everyone
    I have a LG 50PK550 that has no display, i am wondering what the VS and VA voltages should be off of the power supply
    Ken
    Re: Lg 50pk550
    They are indicated on the back of the plasma panel, but in general around 200V for Vs and 60V for Va.
    • kmoonen
      • Dec 2011
      • 61
      Re: Lg 50pk550
      Ok i have no picture at all, all voltages on the power supply check out perfect
        Re: Lg 50pk550
        In a dark room, does the panel appear to glow?
        • kmoonen
          • Dec 2011
          • 61
          Re: Lg 50pk550
          No Glow at all on the panel
            Re: Lg 50pk550
            OK, do you have any sound when you connect a source and blindly change through inputs?
            • kmoonen
              • Dec 2011
              • 61
              Re: Lg 50pk550
              It is hard to say , I tried to change them , but no way to know how the input menu works
              Ken
                Re: Lg 50pk550
                You can download the manual from LG to find out how the menu works.
                  03-31-2024, 02:12 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  07-01-2024, 06:34 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
