LG 50PC3D-UD now no sound
  • captain ron
    • Jun 2013
    • 5
    I first started with a red screen I changed the power supply because the caps were bulging. I next changed the upper and lower buffer board which the tv worked for about an 1 1/2 hour then the y sus board started to click and I changed the ipms on the board I put in two sanyo ipms put the board in and the tv works. Now I am getting when the tv sits for about 12 hours i can turn on the tv and I will get a picture but no sound i can turn up the volume and nothing. But when I go into the menu under audio and flip the check mark from front speaker on to off and then back to on again the sound comes back on to the front speakers I can shut the tv off and come back 4 hours later and the sound will be there but after 12 or more hours not. I am asking what could be wrong or doing this I greatly appreciate the help. Thank you Ron
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • slimmy182
    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
    by slimmy182
    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
    Looking on google I found this:...
    01-14-2023, 11:55 AM
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
