Philips 42PFL5432D no picture
  • oceans4me
    • Jun 2013
    • 13
    • usa
    I could really use a hand with my tv. I replaced a bad capcitor about 2 months ago and it worked fine until about 3wks ago and i have been trying to trouble shoot it. when i plug it in i get a red light and when i push the button i get a green light, if i push it again i get no light. In my attemp to trouble shoot the tv by reading the related posts here. I have replaced several bad caps, D912 shorted, Q901 tested bad IC910, and F901 several times.
    When i measure the voltages for the inverter board i read VBL- 1.65V
    I PWM .968V BLON- 3.29V. This is the same set as member allsmith but a different problem. In tracing the circuit it appears that it gets it power from T905. So i measured the voltages and this is what it reads.
    pin 3 305v
    pin 4 306v
    pin 1 306v
    pin 2 306v
    pins 6&5 -56v
    pins 12,11,10 0v
    pins 9,8,7 0v
    I'm not sure if the transformer is bad or if it gets its 24v somewhere else?
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • Schwoin
    Philips 243v5lhsb00 Monitor Picture too bright
    by Schwoin
    Hey everyone,
    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
    you can see them on the top half of the photo.
    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
    03-21-2023, 12:40 PM
  • madyoyo
    Philips 37pfl560: Yellow picture
    by madyoyo
    HI.
    I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
    Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
    05-30-2025, 10:16 AM
  • charlesdutcher
    No picture issue in Philips Chassis FTL2.1
    by charlesdutcher
    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
    Is there someone having any symptom like this? How to fix it?
    Thanks in advance!​
    08-06-2024, 09:55 PM
  • groomit
    Philips 50PUS7363/12 Backlight but no picture
    by groomit
    I'm having trouble with above mentioned TV. Bought it defect.
    Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
    Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
    I can see backlight, but screen stays black.
    What I've tried:
    - Disconnect right side cable from T-Con -> same (backlight but no pic)
    - Disconnect left side...
    11-22-2024, 02:43 PM
