LCD digital lifestyle LT42322 problem
  • hienton2
    • Sep 2009
    • 183
    I have LCD digital system LT42322.Tv has no back light.I replace
    master and slave inverters. Now tv shows back light but goes off in 3 seconds.
    Tv still on.I can not check the sound.One thing is the logo on screen has green digital and white lifestyles
    And I have to push menu button to turn off tv. and power button to turn on.Weird.
    I already changed 10 caps in power supply. no fix
    Can any body show me how master and slave wire to ccfl light bulbs in panel.I disconnect one side and have one side connected
    to lamp. I still see light in panel on then off.
  • stormanimal83
    Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
    by stormanimal83
    i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
    08-04-2024, 01:47 AM
  • wolf1976
    is there any univarsal wifi motherboard that supports and digital tvs ?
    by wolf1976
    hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
    is there ?
    do you have to suggest me one ?
    thanks on advance...
    01-05-2025, 04:29 PM
  • The WABBIT
    Dell Inspiron 5559 need BIOS Master PW
    by The WABBIT
    I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
    After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
    Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
    07-12-2021, 04:20 PM
  • crushkittykitty
    CMO I420B1-16A (27-D012836) backlight inverter master and slave
    by crushkittykitty
    origanlly the backlight would come on and go off in my great ability to repair I hooked up a test light per instructed master side top 6 would only partially light slave side lit test light fine, pulled tv down to bulbs, same bulbs inside only halve lit. seems master inverter at fault tested all transformers all seem fine, pulled top transformer from master double checking test points reinstalled cleaned up all connections noted on back of master center of board dark spot, checked around that area everything on top of board seems fine, resoldered the 0 resistors plugged everything back in turned...
    07-16-2016, 02:32 PM
  • 66Ton99
    Gigabyte Z790 Aorus Master Schematics Request
    by 66Ton99
    I have a problem with my Gigabyte Z790 Aorus Master, it doesn't run now.
    Looks like I damaged some elements
    But I do not know what's there.
    Please help....
    07-11-2025, 01:56 PM
