Toshiba 42WL66 Continuous Clicking sound
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Ok so this tv has been clicking once u turn it on and there's no whatsoever light on he front of the tv. If u let it click like for few minutes then it comes alive. Once the tv clicking stops, the red light comes up. Its like it needs some heat. Once its working, it will work for ages if u didn't turn it off. I already re solder all the cold joints on the power board, no bulging faulty caps. What else could be the culprit?
    STR-Z4479?
    SRX-2039?
    STR-6765?
    Or the Big 450V 270uf cap? Used a capacitance meter and tested this cap, its only showing 244uf, that's pretty far though.
    Any help will be highly appreciated to guide TQVM
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Toshiba 42WL66 Continuous Clicking sound
    STR-Z4479?
    SRX-2039?
    STR-6765?
    One of the first things I fixed many years ago was a 15" CRT monitor. It did the very thing you just described.
    I found a 12V supply that was below 2V, and slowly increased over about 10 minutes. It never made it over 8V. I clipped a temporary supply in and it came to life. If I removed the temp supply connected after half an hour, it would keep running. And, just like your unit, it would not come back on after being shut off.
    There was a bad cap on that 12V supply- replacing it, fixed it. And this cap didn't look bad, either.
    If I were you, I'd recap, at the very least, that entire power supply.
    Would I assume correctly that this clicking problem has gotten worse over time, and is also worse at lower temperatures?
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Hi kaboom, thanks for the swift reply. I have popped out all the caps and tested the capacitance one by one, all the caps seems to be fine and within its range. Nothing seems to be open or short. Im confused. Could it be one of the IC's thats faulty? Maybe after heating up the IC works fine. Heard about this in couple of forums though.
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        They are not:
        (not my video)
        http://www.youtube.com/watch?v=Cb4wWEWQiQw
        "Basic" cap meters will not show all possible faults!
        They can have high ESR and still "appear" OK on such a tester.
        You are confused because the problem you are looking for is beyond the capability of your instrument. Also, there can be other caps in parallel with the one you may be trying to test.
        Stop guessing and wasting your time. Replace them all and be sure. You have typical badcap symptoms, based on your OP.
        Panasonic FC, FR, and Nichicon PW, PM, HE are some possible choices. I need to know what's in there now to better be able to suggest a replacement series.
        Those caps would be replaced, regardless of anything else, if I was working on that unit.
        You can probably recap that for the same, or less, than a good ESR meter.
        EOL it...
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Ok ive replaced STR-Z4479 and STR-6765. No more clicking no matter hot or cold and tested for almost few days now. Looks like the caps are safe.
          • satinser
            • Oct 2012
            • 214
            If your still active I would be interested to Know whether changing STR-Z4479 and STR-6765 did cure the fault or whether the problem reoccurred. I would be interested because I have exactly the same fault. Like you I tested all the caps with ESR meter and all ok.
            • Sisko
              Onkyo-593 No power and now clicking sound
              by Sisko
              Hi all!!
              Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
              10-03-2025, 02:18 PM
            • B0r1s
              Samsung UE49KS7000SXXH - fast clicking sound in standby mode
              by B0r1s
              PSU - BN44-00878A
              Symptoms:
              The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
              A weak clicking sound was coming from the transformer.
              Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
              Progress:
              After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
              01-17-2023, 04:58 PM
            • slimmy182
              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
              by slimmy182
              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
              Looking on google I found this:...
              01-14-2023, 11:55 AM
              09-06-2024, 05:27 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
