Samsung PN43D450A2D Picture is Distorted
  • pc_doc_al
    • Jul 2012
    • 45
    My Samsung PN43D450A2D has a distorted picture. If there is no motion on the screen it looks good. Sometimes you can see the previous channel bleeding through. When I received the TV it would not power up. I have repaired the X-Main board and upgraded the firmware to the 1006.6 version. I have uploaded a couple of pictures.
    Thanks,
    Steven
    Re: Samsung PN43D450A2D Picture is Distorted
    On the back of the plasma panel (inside the TV), there is a sticker with Vs, Va and Vsc written on it, near SAMSUNG logo and part #. What does it say?
    • pc_doc_al
      • Jul 2012
      • 45
      Vs 205
      va 58
      Vsc -180
      PP42AF085, 42DH
        OK, there are various test points on the power supply for checking these voltages. You will need a digital multimeter, do you have one?
        • pc_doc_al
          • Jul 2012
          • 45
          Yes I do.
            Can you post a picture of the power supply board?
            • pc_doc_al
              • Jul 2012
              • 45
              Here you go.
                OK.
                Set your multimeter to the highest dc range.
                The black probe should be placed on the chassis somewhere.
                The red probe should be placed on the red ringed point, the measurement recorded (Vs), then move to the blue point and record the measurement (Va).
                • pc_doc_al
                  • Jul 2012
                  • 45
                  red (Vs) 204
                  blue (Va) 57
                    Close enough. Can you provide a picture of the Y-main board? This is on the left hand side of the TV, looking from the rear.
                    • pc_doc_al
                      • Jul 2012
                      • 45
                        OK, here is where to test VSCAN (Vsc), test in the same way as Vs/Va tested.
                        • pc_doc_al
                          • Jul 2012
                          • 45
                          Ok I will post it tomorrow.
                          • pc_doc_al
                            • Jul 2012
                            • 45
                            It reads -178 (negative)
                              Close enough, then. Do you see any points for Ve? I am thinking your new X-main is defective but I'm not certain.
                              • pc_doc_al
                                • Jul 2012
                                • 45
                                it reads 90
                                  Although that is not specified, it sounds about right for this panel. I would consider replacing the X-main again; if not, there's a possible problem with the control board.
                                  • pc_doc_al
                                    • Jul 2012
                                    • 45
                                    ok thanks. I replaced some components on the X-Main and did not replace it. That may be my problem. Thanks for your help.
                                      Ah, in which case, what parts did you replace?
                                      • ChattFix
                                        Samsung UN55TU700DFXZA Distorted Picture
                                        by ChattFix
                                        I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                        06-02-2024, 03:50 PM
                                        09-07-2024, 05:50 AM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • JJAAMM
                                        by JJAAMM
                                        Problem
                                        07-06-2023, 06:01 AM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
