Vizio VP50 Smoked
  • aheliason
    Returned Member
    • Dec 2010
    • 17
    Re: Vizio VP50 Smoked
    I am a very happy camper! The Vizio VP50 is up and running. The runs to the two 10 ohm 1W resistors had burned off. Since the board itself had been damaged and removing the resistors also removed the remaining plate-through in the pcb, I secured the new resistors with gold jewler's beads on each side. New wire runs were constructed using one of the resistor leads at each end (the resistors are in parallel). One to the diode D5600 and the other to an area of pcb run that was not burned. That, it turns out, was all that was needed to repair the Y-Main. I had determined that one or more of the chips on the top buffer was shorted. Member Chuckup was able to provide me with a matched set of Samsung y- buffer cards from a HP 50HD V5 which are an older series, but proved to work perfectly in my set.
    All is well and the set is remounted (with the help of another friend!) When time permits I am planning to mount new smt ics on the bad buffer card so that I have a spare set, but as soldering surface mount components is not my forté, this may take some time.
    Thank you to all who commented in this forum!
    • aheliason
      Returned Member
      • Dec 2010
      • 17
      Here is a parts placement video I made after the repair was complete.
      • aheliason
        Returned Member
        • Dec 2010
        • 17
        Could not upload the video. Sorry!
        • Tvbob
          tvbob
          • 204
          Check the panel's voltages they may be high! I have a thread on here
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • TinkerTron
            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
            by TinkerTron
            Hey everyone,
            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
            Instead, here's what's been bugging me so far:
            The schematic...
            03-06-2025, 02:03 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
