Samsung PS42A410 has sound but no picture
  • nick1969
    • 30
    I have a 42" Samsung plasma model is PS42a410 it has working sound but nothing on screen, when i power it up it does everything normal and the LED inside on the control board flashes
    The screen is completely dark no change when turned on
    I have a working 50" that i tried the PSU and Main AV board from but that didnt make any difference
    Any help greatly appreciated!
    Re: Samsung PS42A410 has sound but no picture
    If you connect a source, can you hear any sound?
    • nick1969
      • 30
      i will try a source, with the antenna connected i hear sound from the Local channels
        That's good enough to show the main board is probably working, so we'd be looking at a Y-main or X-main failure. Most likely Y-main.
        • nick1969
          • 30
          Is there some way of checking each to know what's failed?
          Thanks for your help
            Usually there is. Can you post pictures of the boards inside your set?
            • nick1969
              • 30
              Is this ok or do you prefer individual shots?
                Ideally a closer shot of each large board in the set as we need to see the smaller components and get an idea of the design/layout used.
                • nick1969
                  • 30
                  Is this OK ?
                  • nick1969
                    • 30
                    Just to recap, i swapped the only 2 boards from a 50" that were the same with no difference The main AV board (3rd picture) and the PSU (last picture)
                    The Screen is black and no glowing or flickering when powered on, only sound
                    Thank you
                      I've highlighted two fuses on the Y-main. Please measure the voltage on both ends. Highest DC range (more than 200V). Red probe on one end of fuse, black on chassis, swap to other end, repeat for both fuses. Set should be switched on with audio playback. Be careful not to touch any part of power supply while set is switched on due to shock hazard.
                      • nick1969
                        • 30
                        Ok ....
                        The top small green fuse has 14.8v either side and the bottom glass one has 208.2v either end
                          Those are both good readings.
                          Next, test the voltage across this capacitor I have highlighted: red probe on one end, black probe on the other end. It does not matter which way around.
                          This is one cap in the ERC cap bank. Functioning voltage is around 60 to 120V DC.
                          • nick1969
                            • 30
                            I have 97.5v across that cap
                              OK, well, it appears that you should have a glowing screen! But in a dark room would you say there is no visible difference in brightness between the TV being on and off?
                              • nick1969
                                • 30
                                Hi again,
                                Just powered it up in a dark room and nothing at all not even the slightest glow whatsoever
                                  On the Y-main can you see any points marked VSCAN or VSC?
                                  • nick1969
                                    • 30
                                    I see VSCH and VSCAN
                                      Can you measure the voltage at VSCAN? Put red probe on the test point and black probe on the chassis. 200V DC range. VSCAN/VSC is usually written on the panel sticker to refer against.
                                      • nick1969
                                        • 30
                                        VSCAN is showing 0 volts
                                        VSCH bouncing between 42v and 48v
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • mrtek
                                          Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                          by mrtek
                                          Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                          11-26-2024, 09:58 AM
