Plasma LG 50PK550 picture blanks only when hung on wall
  • RCKadath
    • Jun 2013
    • 16
    I have a 3 years old LG 50PK550 tv that has an intermittent problem. After usually about 5 minutes, the picture starts to flicker and shortly thereafter, it goes blank. The sound still works however. This has been going on for only a week or two.
    Here's a little background info that might or might not help. I hung the TV on a wall this summer. About 1-2 months ago, it started making a buzzing sound, correlated to the amount of white in the image (more white = louder buzzing). I read that applying pressure to the back sometimes solves this, so I squeezed a piece of foam between the wall and the TV, and it indeed helped.
    Another bit of info is that 3-4 weeks ago we had lighting strikes around our house. At some point during the storm, the TV developed horizontal lines and an overall bad picture. I thought it was toast but a power cycle fixed it. It remained fine for about two weeks after that.
    Here's the troubleshooting that I've done so far:
    - Removed the TV from the wall and put it on its stand
    - Checked the VA and VS voltages on the power supply. VA is 60V but VS is 202V (supposed to be 201V on the sticker). I don't trust my cheap voltmeter to adjust the voltage however. I'll borrow a Fluke from work tomorrow and check again.
    - The TV is actually working fine when resting on the floor and not hung on the wall! It's been 2-3 hours now and everything is fine.
    Hypothesis #1:
    Hanging the TV on the wall is somehow causing stress in one of the PCBs making if fail. Doesn't quite explain why it would work the first 5 minutes though.
    Hypothesis #2:
    Removing the back panel decreases overall temperatures and it never reaches the point at which it fails.
    I'd appreciate pointers to continue my investigation. I somehow need to make the TV fail again to continue troubleshooting but I can't troubleshoot when it's hanging on the wall... I'll try to simply put the back panel back on to see if it starts failing again.
    Re: Plasma LG 50PK550 picture blanks only when hung on wall
    It is quite likely there is a temperature sensitive component.
    What you can do is take something like a hairdryer and start heating up parts of the set. If you find a part which causes it to go wrong when heated, then you have found the source of the problem.
    • retiredcaps
      • Apr 2010
      • 9271
      Tom66 is the plasma expert.
      Some ideas until he responds.
      1) You can try using a hair dryer with the back case off and gently heating up portions of the board to see if the picture blanks?
      2) Try feeding the TV an all white picture source. I believe white causes the plasma to consumer more power.
      3) See if you can borrow a IR temperature gun?
      edit: Tom66 apparently types faster than I.
      --- begin sig file ---
      --- end sig file ---
      • RCKadath
        • Jun 2013
        • 16
        Thanks guys, I will try with a heat gun tomorrow. Tonight I gotta watch the last episode of Game of Thrones now that I found a way to make the TV work temporarily
        • capkid
          • Oct 2010
          • 1339
          Uh, I wouldn't use a heat gun. I'd use a hair dryer instead.
          LG Plasma Mal-Discharge Correction Service
          • retiredcaps
            • Apr 2010
            • 9271
            RCKadath lives in Quebec. Thus there is a possibility of "lost in translation". Don't worry, RCKadath will know what I'm talking about!
            PS. A heat gun will likely destroy/kill the capacitors on the board.
            • RCKadath
              • Jun 2013
              • 16
              I'm sorry to revive an old thread but for the benefit of Google, I wanted to post the outcome. It appears that it was indeed what I thought, hanging the TV on the wall had caused stress on the PCBs and an audible noise.
              What I did to fix it was somehow impose the same stress to the TV when hung on the wall, unscrew all screws to get the PCBs to be stress-free and then rescrew everything. It worked.
              The hardest part was figuring out how to hang the TV from the mounting screws while having access to the electronics. I did it by hanging the TV with ropes on the ceiling. My wife had a good laugh with that... I did take a picture but too lazy to extract it from my phone at the momment. I'll post it if there's interest.
              Anyhow, it's been 2 months now and no more problems, so I'm quite confident in my fix. Thanks to everyone for your help.
              • KYBOSH
                Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
                by KYBOSH
                This found its way to my workbench this week.
                The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
                Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
                The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
                This reminded me of the eufy floodlight...
                09-06-2024, 09:09 PM
              • ArMaaN376
                Samsung PS51E550 Plasma TV
                by ArMaaN376
                I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                Opened TV cover & observed foll
                a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                How to confirm Y -Buffer board...
                06-19-2024, 04:05 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • alltvrepairs
                Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                by alltvrepairs
                I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                Any one met this problem in the past?...
                10-08-2025, 07:34 AM
