I've been searching for a Y-sus board for my 50" LG plasma it must be a hot item every source says out of stock, No. 6871QYHO39B any suggestions, leads would be appreciated.
Where do I get a Y-sustain for a 50" LG plasma
Re: Where do I get a Y-sustain for a 50" LG plasma
6871QYHO39B appears to be the IPM module? Is this printed on a heatsink? You'd want to order by the number on the board. Be aware boards for these TVs are rare because they fail so much -- it's best to get the IPM part replaced by a company like Coppell TV repair, if you can't do it yourself.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
6871QYH039B is a Y-Sus part number; the "O" is actually a zero.
http://www.shopjimmy.com/lg-6871qyh039b-ysus-board.htm
It looks like you have a few substitutes available. As Tom said, unless you can find a brand new board at a good price, your best option may be to service the board. Coppell is only charging $129 for trade-ins, which is a very good price. The two IPMs, if they are bad, are about $40 each. There's also a chance that other parts are bad on that board.
http://www.ebay.com/itm/Sustain-6871...item255d4e1b2d
Edit: If the IPMs are bad, Coppell may recommend replacing the IPMs on the Z-Sus, also. They apparently wear at the same rate as the Y-Sus and could fail shortly after the Y-Sus is repaired or replaced.Last edited by capkid; 06-16-2013, 12:49 PM.Comment
by PlasMattI have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
Greetings all!
Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could... -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by Salvatore057Hi all,
I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
I am lost, should I change the YSUS board? Is the YSUS board damaging... -
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... - Loading...
