Sony klv 32u300a display problem
--- begin sig file ---
--- end sig file --- -
Re: Sony klv 32u300a display problem
A 0 ohm smd resistor should read around 0.0 ohms. Obviously, if you short out your leads and they read 0.2 ohms (like mine), then a 0 ohm resistor should read 0.2 ohms.
Any reading signficantly higher than 0.2 ohms is an indication that the resistor is bad.--- begin sig file ---
--- end sig file ---Comment
Thanks to everybody.
Problem is solved.
Culprit was RJ58. I show the technician and he made a wire jumper to replace it. All the tubes are now evenly brightened.
Tom, Thanks to you for suggesting not to buy tubes in post no. 18, although I was feeling lucky when I negotiated and was about to buy FULL BACKLIGHT for just US$30 from scrap.
Retiredcaps, Thankyou for informing me that those tiny devices are only jumpers. I think It is easiest task to check continuity. I dont know why it took me so much time. I assume that technician has done his work, but he also missed that.
Thanks Again.Comment
Everything is fine so far except one problem.
It is not showing any video on HDMI. It switches normally to hdmi mode on selection but screen remains blank. I have connected many hdmi device and cables but no success.
I also reset tv by pressing up arrow on remote and power button on lcd panel.
Any valuable suggestions!!Comment
Possibly main board problem due to bad HDMI receiver -- due to copyright protection on HDMI receiver chip you will most likely need to swap entire main board unfortunately!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hello everybody
Set was running fine until it develops new fault. Now it is going into standby mode after giving two red blinks. Can anybody help me to get blink code reference with respect to KLV-32U300A. Do sony use same blink codes for all its lcd models?Comment
Service manual:
http://elektrotanya.com/?q=showresul...oria=&kat2=allNever stop learning
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
- Loading...
