50ps3000 getting hot
  • pete ling
    • May 2013
    • 5
    • England
    I Have an LG 50PS3000 I have just rebuilt the ZSUS board replacing several MOSFETS and still no picture. I then found the switching MOSFET on the Ysus board short that produces the DD voltage stated on the board as 15v. I know have a good picture and all was looking good however after running for a few mins i found the MOSFETS Q13,14 and 15 on the Zsus board where getting very hot so I turned off the set and disconnected the Zsus board to prevent any further damage. I measured the 15vDD voltage and it is about 18v. I have also changed all the caps on the control board after reading some stuff on the net but still getting hot. I have also read that replacement of the control board can cure this fault but other than the MOSFET switching wave form I fail to see how this could help. I have also read that other people have commented on line that there 15v dd is also high so not sure how accurate this has to be?
    also that there is a newer version of the control board with a newer software version to cure the over heating issues ( mine is rev L). could any one advise on these issues
    regards
    peter
    Re: 50ps3000 getting hot
    It is normal for the high power transistors on these to run hot. Any temperature up to around 100°C on the case surface is safe. I recall burning myself on the back of a Panasonic plasma panel -- the heatsink for a PZ80 42" 1080p panel, which ran very hot (around 80°C measured by my thermocoupler.) While a low 15V line would likely cause problems with the MOSFETs and cause them to run a lot hotter than they should, a high 15V would actually be more beneficial (up to a limit of around 20~25V.) This is because it increases the saturation time and drive current of the transistors, meaning they waste less power during the high frequency switching period.
    • pete ling
      • May 2013
      • 5
      • England
      Tom66
      Thank you for the fast reply I have purchased two manuals for this set of the net but both do no contain any information of on the boards I want. I think they may be all the same and if so they are a very poor excuse of a manual. I don't understand why the manufacturer does not put all the circuit diagrams in the manual?
      I understand what you are saying about the MOSFETS I don't have a way of measuring the heat but mine are so hot you can smell them cooking?
      Regards
      peter
        That might be a fault but the only way you will know is by measuring their temperature. You could use something like this
        http://www.ebay.co.uk/itm/Digital-In...item3cd201d4ac
        if you need to satisfy you curiosity. I've used them with success before.
        • pete ling
          • May 2013
          • 5
          • England
          Are they accurate enough? By the way good luck with the studies I am just finishing a masters in electronic product development currently working on the final thesis. I am doing mine distance learning so trying to fit that around a full time job it is hard work.
          Cheers
          peter
            They measure within +/-1.5°C of my calibrated, precision thermocouple reference. Only issue, you can only measure black surface (like surface of transistor or black heatsink.) As they cannot accurately measure reflective surfaces.
            I've had a good first year. Good luck with your studies, too.
            • pete ling
              • May 2013
              • 5
              • England
              Yes I have got a unit on order
              Thanks again
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
                After all of...
                07-13-2024, 08:14 PM
