LCD L32X10M2 menu OSD OK but no picture!
  • Ahakim
    • Apr 2013
    • 64
    I need some help to fix the problem of a PANASONIC LCD TV:
    TV on, with a source signal (from DEMO for instance): sound normal but no picture at all (i.e. black screen). TV (not demo) menus appear on screen normally...Remote control functions perfectly.
    SMPS V outs all good. Would it be an EPROM programmation problem??
    Information on back cover:
    PANASONIC
    Model No: TH-L32X10M2
    Power rating: AC auto 110-240V - 50/60Hz
    Power consumption: 99W
    Made in malaysia.
    PANASONIC CORPORATION
    Many thanks...
    Re: LCD L32X10M2 menu OSD OK but no picture!
    Try doing factory reset.
    VOL- held on TV.
    Menu on remote. Diagnostic pops up, check for any errors.
    Power off TV by unplugging it.
    TV boots as if it were new from the factory.
    • Ahakim
      • Apr 2013
      • 64
      Thanks TOM for the reply. I will try the factory reset.
      Any schematic for this LCD TV?
        I'll try and find one.
        • Ahakim
          • Apr 2013
          • 64
          Yes I tried the the Factory Reset, but no result, nothing has changed at all. Diagnostic says: all settings are OK. Most probably the problem could be in the video part on the main board...Don't you think so? Or should I look elsewhere? Any clues or tests that could reveal the cause?
          Thanks for your time Tom...
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Ierwin
            Philips 58PUS7805 Menu working but no/weird picture from video sources
            by Ierwin
            I got a 58pus7805 that shows some weird behavior.
            The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
            However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
            I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
            I managed to install the latest official firmware by holding the control button while plugging...
            03-10-2024, 12:50 PM
          • FZG
            Panasonic AG-1000B VHS player with bad picture quality
            by FZG
            Hello!
            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
            I want to know, is this something that could be solved by recapping or is the video head likely gone?
            Also, what mechanism is this?
            Any feedback is appreciated!...
            05-06-2024, 07:16 AM
          • Bazfletch3
            Panasonic TH-65FX800A backlight LED's working but picture is very dark
            by Bazfletch3
            Hi all
            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
            From there I envisaged that the backlighting wasn't working, however...
            01-08-2024, 10:18 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
