No Video on my Samsung 55"
+ More Options
Posts
    Re: No Video on my Samsung 55"
    OK, what about LD?
      It sure sound like OLP just like Kevin's Sony that we help him on.
      • MG36
        • May 2013
        • 18
        Both LD measures = 12.34V
          That would appear OK. Low is bad.
          Budm, can you think of any way to easily test the high voltage AC?
          • MG36
            • May 2013
            • 18
            tom66/Budm
            Do you think I have pretty much narrowed down to the power supply? There is also another cable (blue/white wires) running from the backlight converter board (what I've been calling it anyway) across the TV to the left side to a connector (I assume there is a board underneath the metal shield).
            • MG36
              • May 2013
              • 18
              tom66
              Any luck with other ideas or should I order a new power supply?
              • newtothis
                • Mar 2013
                • 1556
                • england
                #27
                If you are handy with a soldering iron hang fire with buying a new psu yet... Narrow it down first and see if its repairable
                  Since all the error signals look OK, then we have to troubleshoot this power supply/inverter output section, but just to be sure in case the error signal happens so fast and we did not see it, I would ground the FB pins to the chassis through 100 Ohms resistor and see what happen.
                  What is the P/N of this power supply/inverter board? BNXX-XXXXX
                  You can test and see if the high voltage is present for second by using CFL like this.
                  http://s807.photobucket.com/user/bud...tml?sort=3&o=0
                  http://s807.photobucket.com/user/bud...tml?sort=3&o=1
                  Just touch the probe to the high voltage out put terminal, it should flash the lamp in your hand.
                  http://s807.photobucket.com/user/bud...tml?sort=3&o=3
                  • MG36
                    • May 2013
                    • 18
                    Part Number of PWR SUPP=BN44-00268A
                    I have not been able to obtain the resistor to test the gorunded FB pins hopefully this weekend. thanks
                      I don't have a schematic unfortunately
                      • MG36
                        • May 2013
                        • 18
                        I'm good with soldering are there parts that I can just replace to see if it fixes the board without having to test the HV. It would be easier to get the CAPS or other components then trying to buy a CFL and do the test...
                        • MG36
                          • May 2013
                          • 18
                          tom66
                          so are there any components I should replace on this board? I am thinking of just buying a new board...
                          • wirenut495
                            • Sep 2014
                            I have a the same tv and it sometimes goes pink and snowy then pops back into normal operation, i first thought it could be hdmi cables but it still has done this , but no set time or reasoning i was wondering is this a common occurrence and if so anyone know what the issue could be
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                              This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 06:20 PM
