sony,kdl 32s30xx,standby
  • shawy123
    • Nov 2012
    • 11
    • england
    after switching this tv on it will go to standby and not switch on,on blinking of the led,
    Re: sony,kdl 32s30xx,standby
    How long does it last after being powered up, does it instantly turn off or after 5 mins etc.?
    • shawy123
      • Nov 2012
      • 11
      • england
      when you turn it on it lasts for 5 mins then its standby mode
        OK, in which case, I suggest you try heating parts up and seeing if you can get it to shut off quicker, if you do, you have found a suspect area. Hairdryer or hot air gun works well.
        • shawy123
          • Nov 2012
          • 11
          • england
          thanks but it now is on standby when u switch on,then blinks 4 times.
            What is the full model number of the set?
            KDL-32S30XX does not look like Sony model number.
              03-31-2024, 02:12 PM
            • Seb932
              LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
              by Seb932
              i'would like to fix my not working LG 49UB850V tv.
              Symptoms:
              -AC plugged in, Standby LED not working
              -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
              Checked already:
              -Powersupply Output in Standby => 3.5V ok
              -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
              Any suggestions what to check next?
              Thanks in advance!
              09-14-2023, 06:28 AM
              07-01-2024, 06:34 AM
            • rju
              Samsung 60" Plasma TV, Blinking Standby LED
              by rju
              A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
              Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
              Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
              07-21-2020, 05:23 AM
            • mecha1166
              QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
              by mecha1166
              I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
              03-28-2024, 08:31 AM
