Dell W4201C
  • bluto
    • Oct 2007
    • 560
    Dell W4201C
    I have not worked on a plasma before only LCDs. My friend send me this picture of his Dell W4201C with the top half of the screen looking funny. I looked around a little and it seems like it is one of the buffer boards. I am looking for any advice on fixing/replacing the boards. Can this be fixed or is a new board in order? Is it best to replace both buffer boards at the same time?
    Thanks for your help.
    Re: Dell W4201C
    It really requires a new board as usually all the chips on that buffer are dead when it is like that.
    • bluto
      • Oct 2007
      • 560
      Re: Dell W4201C
      Yeah I figured as much. I was just watching a yt video where the guy determined which IC was shorted and removed it. But like you say another one on the same board could be waiting to go. So just replace the upper buffer board on this TV since it has not shorted and harmed anything else? And I will check it for bad caps too!
      • capkid
        • Oct 2010
        • 1339
        Re: Dell W4201C
        What Tom was saying is that all the chips appear to be going; there isn't just one chip that is failing. Also, they haven't fully shorted, so you won't be able to detect issues with a meter. This TV appears to use the dreaded LJ92-01200A/LJ92-01202A/LJ92-01203A Y-Sus/buffers combo. I'd personally replace just the upper buffer, since the TV is old. However, your lower or a replacement USED upper could go at any moment in a more catastrophic fashion and take out the Y-Sus.
        http://blog.coppelltvrepair.com/2010...according.html
        LG Plasma Mal-Discharge Correction Service
          Re: Dell W4201C
          Yeah the buffers aren't just shorted as capkid says, they are just bad. When they do that they are selecting more than the current line as they should so the image becomes a sum of multiple lines. I guess something inside them fails consistently.
          • bluto
            • Oct 2007
            • 560
            Re: Dell W4201C
            Yeah I get that it is not shorted. It seems like to attempt a chip replacement would have bad ROI and more or less be a game of whack a mole since another one of the chips is probably soon to fail (and could take out the Y-Sus). Here is the video that describes removing and replacing a chip from the buffer board: http://www.youtube.com/watch?v=5hVi5gd0aec
            Since the most that I have done is a remove and replace a 16-pin SMD, I think this is a bit out of my league. But interesting and educational none the less. So in this case, since it is the infamous Samsung Y-Sus/buffer trifecta, and the buffer is not shorted the options are to A. Replace only the one buffer that is bad with a used or refurbished buffer. or B. Replace the Y-Sus and the buffers with the kit from coppel_tv that has the newer style buffers with four chips per buffer instead of six. The latter is more expensive but has the best chance being a lasting repair.
              Re: Dell W4201C
              You will only need to replace one or both buffers. The Y-main can be left as-is.
              • capkid
                • Oct 2010
                • 1339
                Re: Dell W4201C
                IMO, ALL of your chips on that board are bad. You're correct that replacing those chips is an advanced and delicate procedure that I wouldn't consider if you've never done it, especially since you'll have to replace all six chips in this case.
                • bluto
                  • Oct 2007
                  • 560
                  Re: Dell W4201C
                  Six chips times two boards for a really thorough repair < I would just replace both boards
                  This would be my formula for success in the given equation considering my skills. But if you are really experienced in SMD re-work, the equation might be different.
                  I guess wasn't clear about the Y-Sus. Coppel sells a kit with the two newer version buffers and a Y-Sus which is what I was referencing. I guess you could ask them for a better price for just the buffers. That would be more appropriate in this situation.
                  • capkid
                    • Oct 2010
                    • 1339
                    Re: Dell W4201C
                    Yeah, if I remember correctly, the newer buffers they sell have just four ICs. They more than likely can sell you the buffers separately. I've dealt with them previously, and they're fairly accommodating.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • lalle-
                      Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                      by lalle-
                      Hello!
                      I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                      [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                      I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                      The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                      I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                      08-11-2024, 02:01 PM
