sony kdl 52 vl 150 tcon
  • baba13
    • Feb 2013
    • 12
    • us
    did anyone try to repair tcon it self,or any leed what can be bad on this board
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • iglitare
    Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
    by iglitare
    i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
    Backlight seems to work, Sound (Setup menu after reset) works.
    If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
    Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
    With my small knowledge i would think at least the cables are good.
    Can this happen because of a bad tcon board?
    Or is it always a bad/shorted...
    09-04-2025, 07:13 AM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • thelankanguy
    Sony KD-55X9000F TCON Issue
    by thelankanguy
    The TV shows a black screen with no image.
    TCON ribbon connectors were disconnected individually for image and there was no half image even.
    Later both ribbons were disconnected and TCON voltages were tested.
    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
    There is also a short to ground in this circled inductor.
    Is this a TCON issue or something else ?...
    12-13-2024, 12:27 AM
  • bbrain
    Sony KD-55AG9 TCON?
    by bbrain
    I have this problem with my Sony 55' AG9.
    It flashes 4x.
    I have found the service manual, and seems it is the TCON.
    Before I buy a TCON can someone check the vid?
    Thanks in advance!...
    09-19-2024, 10:50 AM
