LN40C610 40" LCD Samsung no H.V.
  • mrsbean
    • May 2013
    I replaced the p/s bd
    the LED power on is lit
    and i get a volt on the p/s bd, when i capacitively iduce a potential from the [power on bd]
    thru the main bd, to the p/s [pwr/supply PCB ass'y]
    on the p/s bd @ 120vac mains power [no tyr turn on] the only voltage p/s bd is std 6v [high but this is A 5v]
    on the p/s bd and only for 8sec's, I will have B 5v, Vcc 15v [probably 2v hi] there is also a 12vdc @ LD i guess this is going to p/s to step-up to HV high voltage [not sure]
    the ps_on is sitting mv when finger press pwr/on it goes to a volt
    so to re-cap...
    ...the HV was unplugged to see if the 5v 12v & 13v would stay...no
    ...the panel bd [thin ribbon conn] was unpluuged to see if V's would remain 8sec's...no
    looked like p/s bd problem so replaced it = same
    my gut says main bd is shutting it down
    maybe it doesn't like that the 5v = 6v & the 12v=13v & the 13v = 15vdc
    i am an old school tech fixed a few of everything
    master of nothin' cept baiting
    i hate to buy a main bd now that i spent $123+ on p/s
    is there a voltage reg [ic] that is also a tripler on the main bd?
    b/c we only have 5v working [not die under load]
    funfit55@gmail.com
    i am steve from Vancouver canada
    i havent done repairs in years [late 80's early 90's throw away give away working]
    Re: LN40C610 40" LCD Samsung no H.V.
    What is the P/N on the power supply board? BNXX-XXXXXX
      09-07-2024, 05:50 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • JSin21
      Compatibility of main boards between different variations of samsung MU6100
      by JSin21
      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
      I have Samsung Smart TV UA65MU6100WXXY version DA01
      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
      11-27-2023, 04:54 AM
    • mrautom8
      Samsung TV UN75H6350AFXZC main board schematics?
      by mrautom8
      Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
      Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
      While relay is on, all voltage rails are present and steady (scoped) on main board.
      I love a good logic puzzle but getting lost without any schematics.
      No shorts on ANY capacitor main board.
      Thermal camera shows 3.3V inductor getting warm instantly but...
      10-19-2025, 06:32 PM
    • Yanleb
      Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
      by Yanleb
      Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
      If they are not compatible why did Samsung give them the same part number to begin with?
      08-04-2025, 11:35 PM
