My roommate and I are thinking about attempting to fix my Panasonic that just gave me the 10 blinking lights a few days ago. I know nothing about tv repair, computer boards, etc. He knows a little bit. His fixed a computer or two. Is this task something we could tackle the two of us?
Trying to fix my tv myself
by ashr88Hello, I have an Lenovo Thinkpad E590.
It displays the bios splash screen then displays the following error and turns off.
"BAD CRC of Security Settings in EFI variable"
Bad SVP Data, stop POST task....1 Photo -
by smic717394Hi,
I need a bit of help. I have a Macbook pro end 2011 8.2. I bought it of a customer cheap because it has a bulged battery. I replaced the battery and upgraded the ram 2x8GB total 16GB, and replaced the HDD with a SSD. What happens with this laptop is very strange and I don't know where to begin. The laptop doesn't panic, tha fans run normal even when the kernel is 100%. If I reset the SMS, will run normal for about 30 to 1 hour then the kernel_task goes to 95% and the laptop become unusable. If I reset the sms agail will run again normally for some time. I thought is the battery,... -
by cyngoThis notebook which turns on but screen with error 'Bad SVP Data, Stop Post Task' and then power turns off.
how to solve this problem? Please help
thanks in advance.
original bios...-
Channel: BIOS Requests ONLY!
thanks in advance. -
by reformattCouple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade... - Loading...
