Lines on Sky PDS4250 Plasma TV
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok guys not been on this in a long time. had a mate ask me to look at his tv its model number is above, first TV ive ever even seen from sky (never knew they made them) but as pictured i have 2 lines going down the screen, what could possibly be causing this ?
    Re: Lines on Sky PDS4250 Plasma TV
    Cold solder joints on the flex going to the plasma panel.
    I think Sky were selling these with their TV packages a while ago... Just an LG plasma panel inside.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      this sounds so dumb to you i bet !! how do i repair the cold solder joints and how can i find them ?
        Pictures of the chassis first.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          tom i noticed that some silver things on one of the boards are a little bulged, i replaced these with caps on a tv before with power problems and it fixed the board. tried to take some clear pictures. if you need more let me know thanks
            They're probably OK. They normally look a little like that.
            Sorry, but your pictures are next to useless, I can't see anything...
            I need one of the chassis so I can tell you where to look, remember, I don't know this TV or have it in front of me.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              is this what your after Tom66 ?
                Great, thanks.
                Can you get me a picture of the sticker in the top right I've ringed? In fact one of each of the stickers would be useful. I can look up service information using them.
                Also, I've highlighted some of the visible driver packs for the columns. You will need remove the main board assembly to access the rest of them. Basically you want to unscrew the module, carefully detach the flex, then get me a picture of what's under there (need to know if it has resistor-on-flex or not.)
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • xNOTx
                  Verticle lines on Samsung PN42A400 Plasma TV
                  by xNOTx
                  Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
                  [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
                  04-30-2024, 04:22 PM
                • afex
                  Samsung Plasma TV with vertical lines (model PN50B430P2D)
                  by afex
                  This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                  This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                  I have attached an image of the TV with these bars displaying....
                  11-08-2021, 09:23 PM
                • thetonywarren
                  Samsung PN51E450 Plasma Vertical Lines
                  by thetonywarren
                  Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                  Any help would be appreciated.....Please let me know.......
                  02-14-2022, 01:23 PM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
