LG Plasma CTRL ROM 42V7
  • Clydeuk
    • Jan 2012
    • 193
    Hi. I'm desperately looking for a source of ROM file for a PDP42V7 PDP (Non- vzb). I think the file I need is 42V73DNCS1 or 42V73CS4AD.
    The original ROM was 42V73LA2A, I flashed a file I had in but got blank display, though on board test patterns were fine. Biggest problem I have is that I have to remove the IC to program it.
    Any advice?
    Re: LG Plasma CTRL ROM 42V7
    See this ZIP.
    http://www.tgohome.com/ServiceManual...h=Submit+Query
    • Clydeuk
      • Jan 2012
      • 193
      Thanks. I think I already have that one which appears to be for the KIT, but I've got nothing to lose here apart from some time so I may give it a go. The problem is that this is a cheapo TV I've had for ages, the PDP is a 42V7 but the boards are not the same numbers as in the LG service stuff that I have. My boards are Y-SUS 6871QYH045D, Z-SUS 6871QZH049B and CTRL 6871QCH066H. The CTRL ROM was 42V73LA2A dated 051210.
      Wish I'd downloaded more of these files while I had access to the LG site
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
      • to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
        by to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
        I have opened the laptop and identified the main BIOS chip...
        10-24-2025, 01:35 AM
      • Forest79
        by Forest79
        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
        07-23-2023, 07:39 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
