Phillips 50pfp5332/37
  • topfli8979
    • Oct 2012
    • 311
    Picked up a 50 Phillips Plasma tv, that would turn on for 5 minutes then shut down. Ordered a set of boards found, bad pfc on power supply, and bad main tuner board.
    So everything is working properly now,EXCEPT for when you go to shut tv down, screen shuts off as it should, but main board and power supply stay on? Never seen this issue before, the only way I can get tv to fully power down is to unplug it.
    Re: Phillips 50pfp5332/37
    How do you know the two boards are still powered up?
    • topfli8979
      • Oct 2012
      • 311
      The green led's are still lit. And I don't get the relays clicking to power down.
        After it "powers down", can you turn it back on again?
        • topfli8979
          • Oct 2012
          • 311
          yes. But there is no relays clicking on power up either, its not shutting down all the way, just turning the pdp off.
            Perhaps it has a timer recording enabled? My Panasonic uses 20W if a timer is scheduled, even if has not yet come on.
            Tried a full factory reset?
            • topfli8979
              • Oct 2012
              • 311
              That was it TOM66 ! Reset to factory settings all is well. Its always the eastiest thing, that I manage to overlook. Thank ya much.
              • bffargo
                2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                by bffargo
                LG 60PB66550 NOV 2014
                PSU: EAY63168603
                PCB: EAX65359531 2013.11.01 Rev:1.0
                Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                Symptom:
                While watching, just went black and started clicking relay every few seconds.
                Initial diagnosis:
                Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                Deeper diagnosis:
                Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                09-09-2022, 07:34 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
