sharp lc32l400m
  • willyam1
    • Feb 2012
    • 112
    • israel
    sharp lc32l400m
    hi.
    problem no sound in all inputs.
    when I touch in my finger in the smd ic amp ther a noise in the speakers that means that the amp is om no inp signal in the ic( pin 3and 7).
    try even the manu reset and the factory reset no joy.
    am I missing something in the reset procces or just to order the main board.
    thanks willyam1
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • Mitike
    SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
    by Mitike
    Hello guys,
    I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
    According to other sharp SM-s it is lamp error (I can't find SM for this model)
    And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
    If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
    02-16-2020, 08:11 PM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • ictc
    Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
    by ictc
    I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
    Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
    The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
    02-25-2025, 12:15 PM
  • kotel studios
    ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
    by kotel studios
    Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
    Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
    I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
    12-14-2024, 10:48 AM
