Jvc lt-47em59
  • tvqualityparts
    • Feb 2013
    Jvc lt-47em59
    Hello everyone. I'm a rookie tech so all the help will be very appreciated.
    I have a JVC LT-47EM59 that has like a 3-inch wide dimmed vertical line in the center of the screen. And sometimes half of the screen shows picture and then only half shows. I have attached a picture.
  • Raulnn
    TD Systems K50DLG12US half black and half white screen
    by Raulnn
    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
    01-20-2024, 04:49 PM
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • bohaboha
    Samsung UE55KU6575U SHOWS ONLY HALF SCREEN
    by bohaboha
    hi As the title says this curved tv works but shows only half the screen wondering where the fault lies thanks.Here are some pictures
    Note: First and second pictures show the back of the TV the side that works very dark picsorry...
    09-15-2020, 06:53 PM
  • Stanley1843
    Dell Inspiron 15 3520 - AC Adapter shows "Not Installed - Not Charging
    by Stanley1843
    I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?...
    09-27-2025, 08:44 PM
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
