plasma tv out of service
    Re: plasma tv out of service
    I've never seen that diagram before I guess it must have been reverse engineered.
    Vs = Vset probably for R14, otherwise it does not make much sense.
    • takara
      • May 2013
      • 19
      • france
      you right tom66
      Vs = Vset on R14 but I noticed there is no Vs voltage on R24 and R26. It seems that the Vs voltage (183 volt) coming from the power board is defective in some parts of the y sustain board.
      The vscan voltage is ok = 115 volt
        See if there are any fuses or fusible resistors you could have overlooked?
        • takara
          • May 2013
          • 19
          • france
          hello tom66
          I have already check the fuse from the vs voltage and it is ok. If this fuse did not work, i will not have vscan voltage on the ysustain board
            I meant fuses for the Vset voltages, and other voltages, not the Vs fuse.
            • takara
              • May 2013
              • 19
              • france
              #26
              there are two fuses in the y sustain board. one for the vs voltage and the other one for the +5 voltage. there are ok after my measurement.
                Can you test the Vset etc. DC-DC packs out of circuit?
                • takara
                  • May 2013
                  • 19
                  • france
                  #28
                  yes I have made the following measurements and I get :
                  Vscw = 114 volt
                  -Vy = - 1 volt
                  vset = 0 volt
                  Vs = 183 volt
                  Va = 65 volt
                  there are 2 inverters. one for the Vscw and the there one is for Vy. I have change almost all components around the Vy inverter but no result
                  • Clydeuk
                    • Jan 2012
                    • 193
                    #29
                    I believe Vset is the VSet Up which affects the width of a small part of the top of the sustain waveform, if that's the case you may not get a reading, only a scope would tell you if that's working. -Vy should be much more than 1 volt though, sounds like one of the DC DC converters isn't working or it's driving into a short-circuit.
                    • Clydeuk
                      • Jan 2012
                      • 193
                      #30
                      Is that a 50X3 PDP?
                      • takara
                        • May 2013
                        • 19
                        • france
                        #31
                        hello clydeuk
                        the model of my tv plasma is PDP42V7 from LG
                        • takara
                          • May 2013
                          • 19
                          • france
                          #32
                          hi clydeuk
                          normally the Vy voltage is -95 according to the specifications. you suggest that the DC DC converters isn't working or it's driving into a short-circuit but I think the second option is more interesting
                          • Clydeuk
                            • Jan 2012
                            • 193
                            #33
                            Oh 42V7, I have one of those panels, working order but very speckly, when I get back home (I'm away a few days) I will see if I can find out more. I'm thinking -Vy where your problem is, whatever the reason why it's not coming up. I need to look closer at mine as it's been a long time, but we could always compare readings between mine and yours. Can't remember if I ever had a diagram for this, I'm thinking probably not.
                            • Clydeuk
                              • Jan 2012
                              • 193
                              #34
                              The -Vy and Vscan (Vsc) I believe the DC converters on this version not on separate sub pcb's but on the main Y Sus PCB. I think IPM failure is less of a problem with these as some of the others, but I only have a small sample to base experience on. I can however when I return home take some resistance readings around the -Vy and the output FET's and and semi's around there, we may get some idea if something is amiss or whether to focus directly on the DC DC section.
                              • Clydeuk
                                • Jan 2012
                                • 193
                                #35
                                Quickly glancing at the diagram you posted I think some fusible resistor or other fusible device has opened depriving some (not all) sections of the Vs supply. Again something could be short-circuit, it can be hard to diagnose these stages in-circuit due to parallel paths, parallel FET's etc. That's an interesting diagram though, it appears to be an abstract of the basic circuitry.
                                • takara
                                  • May 2013
                                  • 19
                                  • france
                                  #36
                                  hi clydeuk
                                  thank you for your reply
                                  the DC converters for the -Vy and Vscan (Vsc) on this version are on the main Y Sus PCB. I heard the problem is due to the IPM failure so I changed it but no result.
                                  I've found only two diagrams related to the Ysustain board but there are not a full diagram.
                                  • Clydeuk
                                    • Jan 2012
                                    • 193
                                    #37
                                    This is always a problem that sadly is common nowadays, lack of detailed circuit diagram. I have little doubt you could get it going by fitting a Y-SUS board, however for me it is more interesting to find the exact problem, I grew up repairing CRT sets and by getting in deep to the circuit you gain very useful knowledge which you can use many times and adapt to suit different designs. If in the end you find it's cheaper to replace the whole board than try to source the component(s) then ok. I don't think your problem is IPM related since I think this only provides the basic sustain waveform and the various external circuitry builds on this to achieve the actual waveform required by the display. Can I ask do you still have a picture since replacing the IPM and the accident with the probes?
                                    • Clydeuk
                                      • Jan 2012
                                      • 193
                                      #38
                                      Do you have the PDP42V7 LG manual? It does not have any schematics but it does show a lot of waveforms together with some general info about the pass top and bottom FET's, they suggest they are failed but the same effect would be seen if they are not receiving the correct supplies or signals. I don't want to waste your time with this manual if you already have one to hand as it doesn't tell us much, but if you don't have it maybe it's something to look over.
                                        Alignment guide for many panels including 42V7.
                                        • takara
                                          • May 2013
                                          • 19
                                          • france
                                          #40
                                          hello clydeuk hello Tom66
                                          I noticed no changes since replacing the IPM . I mean the picture with osd is still dark. the sound is ok. When you switch on the tv, some black stains appears on the screen. After several minutes these stains disappears.
                                          Thanks to the tom66's guide, I'm going to check the pass top and bottom FETs if they are failed or not.
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • chazh
                                            LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                            by chazh
                                            This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                            I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                            The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                            09-01-2025, 08:56 PM
                                          • AustinCER
                                            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                            by AustinCER
                                            Hello, I currently have a Dell XPS 8940 in our office for repair.
                                            Service Tag: HG1Y673
                                            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                            07-15-2025, 05:28 PM
                                            Acer Aspire A317-33-P9DS + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A317-33-P9DS + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-33-P9DS + Extended Service Plans boardview and A317-33-P9DS + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 02:20 AM
                                            Acer Aspire A517-52-54PS + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A517-52-54PS + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-54PS + Extended Service Plans boardview and A517-52-54PS + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
