plasma tv out of service
  • takara
    • May 2013
    • 19
    • france
    hello,
    I own a plasma tv which does not work now . the sound is ok but display is dark like a photographic film. I found the -Vy voltage in the Y-sustain board has between 0 and -6 volt. I heard this problem could be provoked by the inverter into the board.
    I will appréciate some help to fix this failure.
    Re: plasma tv out of service
    Can we see a picture of the problem?
    • takara
      • May 2013
      • 19
      • france
      hello,
      I can send a picture of the probleme. I forgot to announce the model of my TV plasma : PDP42V7
      regards,
        That does look a little like low -Vy might cause that. -Vy can sometimes be brought down by a bad buffer board.
        • takara
          • May 2013
          • 19
          • france
          hello Tom66,
          thank you for your reply. you suggest to check the buffer board but I do not kown where is it located on the tv.As I said previously, I read a book which shows an inverter producing this famous -Vy voltage. This inverter is surrounded by a optocopler, transistor an IC model NCP1200D6 and 4 condensators.
            Can we see a picture of the boards in your TV. I will highlight the buffer board.
            • takara
              • May 2013
              • 19
              • france
              please find below the picture showing the boards of the tv.
              • takara
                • May 2013
                • 19
                • france
                I read the specifications indicated behind the screen : the -Vy voltage must be at -95 volt.
                I've made also some measurements with the vsc, va and vs which are OK.
                  On your panel the buffers are on the left of the image. It's the boards that connect to the Y-sus where you measure the -Vy etc.
                  • takara
                    • May 2013
                    • 19
                    • france
                    Hello tom66,
                    I have disconnected the buffers from the Ysys board but the Vy voltage is still the same (between 0 and 8 volt). it is not stable. Normally the specification for that is -95 volt.
                    In addition, I've forgot to tell you there is 0 volt at the Vsetup voltage. Normally the specification for that is 183 volt.
                      You probably have a short somewhere on your board bringing down those voltages, but locating that will be tricky.
                      • takara
                        • May 2013
                        • 19
                        • france
                        I noted that I heard a noise (Bzzzz) every 2 or 3 seconds near or under the IPM heatsink.
                        The IPM could be in short circuit even if the fuse is not blown ?
                          That is possible, we have heard of buzzing IPMs before being dead.
                          • takara
                            • May 2013
                            • 19
                            • france
                            thanks Tom66
                            Could I disconnect the control board connector from the Ysus board to test if I note some changes ?
                              I'd expect no image at all...
                              • takara
                                • May 2013
                                • 19
                                • france
                                you right !
                                I also wondering if the 2 mosfets STP9NK70ZFP which are attached with screw can bring down the Vy and Vsetup voltage. I cannot test them directly on the ysus board. I have to desolder them before.
                                  Where are they, can you highlight them on a photo?
                                  • takara
                                    • May 2013
                                    • 19
                                    • france
                                    hello
                                    yes I can highlight the 2 mosfets on the attached picture. There are located on the left hand side.
                                    Yesterday I made a mistake. I wanted to test the resistor R4 but I did a short circuit. The lead of my multimeter has touch one of the leg of this standard resistor R4 and the other leg of a cms resistor. A short circuit appeared and the 2 resistors became black. The tv switch off (stand by mode) automatically as a security position .
                                    The value on these resistor is still OK but now they are black
                                    Is the Ysus board out of service now because of this short circuit ?
                                      I suspect it had a fault previously, so you have only made it a little worse -- unfortunately, due to the lack of schematics for these boards, you may be stuck with trying to find a replacement board. The cost of repair may exceed the cost of a replacement.
                                      • takara
                                        • May 2013
                                        • 19
                                        • france
                                        hello tom66,
                                        I have replaced the ipm but the problem is still there : no Vy voltage. In addition, there is no Vs voltage on the resistor R14 (please see the diagram attached).
                                        do you have any idea ?
                                        thanks
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • chazh
                                          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                          by chazh
                                          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                          09-01-2025, 08:56 PM
                                        • AustinCER
                                          Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                          by AustinCER
                                          Hello, I currently have a Dell XPS 8940 in our office for repair.
                                          Service Tag: HG1Y673
                                          The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                          Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                          Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                          07-15-2025, 05:28 PM
                                          Acer Aspire A317-33-P9DS + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A317-33-P9DS + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-33-P9DS + Extended Service Plans boardview and A317-33-P9DS + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 02:20 AM
                                          Acer Aspire A517-52-326E + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A517-52-326E + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-326E + Extended Service Plans boardview and A517-52-326E + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
