Lg 60pg7000
    Lg 60pg7000
    Oh I got to see a beast of engineering today.
    60" LG plasma, full HD.
    Fault is that it is slow to start up, sometimes makes a squeaking sound from speakers, sometimes doesn't turn on. When it fails to turn on, the power LED flashes green, before going back red. It will repeat the cycle until it has booted up, which may take 5 ~ 15 minutes.
    I checked the service menu and found the power offs to be labelled as "POWER_OFF_BY_ABN"; which means "powered off due to abnormal condition".
    The power supply was a Sanken part with excellent quality capacitors, so that was ruled out, for now. The fault appears to be on the main board. May get pictures later, if I can! It looked actually really well made. No hybrids.
    New main board is £45, I am repairing this for a friend, unfortunately I don't get to keep it!
  • Rictech
    Panasonic SA-MAX770PU SMPSU board fault....
    by Rictech
    Hello everyone. 😀
    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
    There are no devices that have exploded or otherwise show signs...
    08-26-2024, 01:05 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
    ESR meter came to the rescue again today with a PLC I/O card fault
    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
    12-18-2023, 08:17 PM
  • cazi1001
    Strange fault on Lenovo ThinkPad E14 Gen. 2
    by cazi1001
    I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
    The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
    On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
    03-24-2024, 04:16 AM
  • PanicMechanic
    Extech EX330 multimeter current range offset fault
    by PanicMechanic
    My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
    The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
    As you can see from the pics, the offser is the same (just multiplied for other rages):
    -4.9 uA
    -0.49 mA
    -0.49 A
    I don't know what exactlly caused the fault.
    The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
    05-11-2021, 11:13 PM
