philips 42mf521d/37 no picture -
  • techmadman
    • Feb 2013
    • usa
    hello all i have literally replaced every board in this tv and still have no picture.
    im getting voltage to all boards, have replaced both lc inverter boards, power supply, t-conn board, and main board.
    does antone know what the voltage should be at the fuse for the slave lcd inverter, im getting 24v to board through harness but at he fuse im reading .6v on one side and nothing on the other side. please keep in mind that all parts have been replaced and still no progress.
    any help would be greatly appreciated.
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • Schwoin
    Philips 243v5lhsb00 Monitor Picture too bright
    by Schwoin
    Hey everyone,
    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
    you can see them on the top half of the photo.
    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
    03-21-2023, 12:40 PM
  • madyoyo
    Philips 37pfl560: Yellow picture
    by madyoyo
    HI.
    I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
    Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
    05-30-2025, 10:16 AM
  • charlesdutcher
    No picture issue in Philips Chassis FTL2.1
    by charlesdutcher
    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
    Is there someone having any symptom like this? How to fix it?
    Thanks in advance!​
    08-06-2024, 09:55 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
