Insignia ns-p501q-10a Cycling on and off
  • ludomonster
    • Apr 2013
    • 6
    • usa
    I have an Insignia ns-p501q-10a 50 inch plasma that began cycling on and off last night.
    I am considering having someone repair it, but if I can troubleshoot the problem on my own, I might as well do it myself.
    I took the back panel off to try to see if cleaning the fan would help it. It didn't. There is no fan to clean.
    I did see a whisker that may have shorted out a capacitor; however, clearing out that dust did not solve the problem. I didn't check the fuse on the power supply. Right now, I don't suspect the fuse.
    When I plug the TV in, it automatically begins to cycle. I can hear one solid relay firing followed by a few taps. Shortly after that, the relay fires again, turning the TV off.
    During this time, the power LED on the from of the TV turns solid, then blinks. I don't know if this is a diagnostic code or if it's just a symptom.
    I didn't see or smell any smoke when this started to happen. Also, the capacitors didn't appear severely deformed. I will have to take a look at them later.
    What can I do to ensure that the PS is faulty? If a bad capacitor is the culprit, is it worth replacing vs the whole board? I haven't soldered in 15 years and never really was great at it.
  • ludomonster
    • Apr 2013
    • 6
    • usa
    Re: Insignia ns-p501q-10a Cycling on and off
    Update: I found the manual for the TV and I'm going to use the troublshooting procedure relating to the relay cycling issue.
    • SuperSkippy
      • Nov 2012
      • 58
      When you say it cycles on and off, do you ever get any picture? Or does it just flash the light a lot?
      • ludomonster
        • Apr 2013
        • 6
        • usa
        There's no picture. The power indicator LED flashes. I unplugged the power to the Y board and the power cycling and flashing LED symptoms went away, leading me to supect that it's the Y board. The Vs voltage to the board is 209V. The boilerplate states that it should be 210V. I'm assuming that it's within tolerance.
        I don't have an oscilloscope, so I can't do any waveform analysis.
        The board is running at just under $200 to replace it. A few sites list the board for less, but are out of stock. Given that this TV is a few years old, I'm assuming that these sites won't be restocking this part. I also looked for the part for the equivalent Samsung model TV.
          209V is fine for Vsus, typically tolerance is +/-1V.
          The fault on these often turns out to be four transistors on the lowest heatsink (looking at the board as installed in the set.)
          • ludomonster
            • Apr 2013
            • 6
            • usa
            Is there anything I can do to confirm it?
              You can check between each pin (1-2, 2-3, 3-1) for short circuits on the diode test. A result of less than 200 is suspicious. Once a suspicious device is located, it needs to be removed and tested out of circuit.
              • ludomonster
                • Apr 2013
                • 6
                • usa
                OK, thanks.
                • ludomonster
                  • Apr 2013
                  • 6
                  • usa
                  I found two MOSFETs attached to that heatsink that scored 0 on the diode test across the 3 - 1. I won't be able to remove them for a few days.
                    A quick test is to chop at least two of the leads off close to the PCB to isolate them, then you can see if the devices have any shorts. Also you need to get the part number of the device because some devices like diodes have a connection between the two outer pins.
                    • CoppellTVRepair
                      • Dec 2010
                      • 39
                      Responding here, albiet with significant delay, for hopefully the benefit of those still in need.
                      We're component level service center for TV boards and since there's a particular shortage on market for particular board for The NS-P501Q-10A I am allowing myself to plug in here.
                      The two most common failures in NS-P501Q-10A are the X-Main LJ92-01688A and the Y-Main LJ92-01689A boards.
                      They fail independently from each other, just because of wearing out (yes, electronics wear out, due to thermal cycles of expansion and contraction of semiconductor junctions during periods of activity and inactivity).
                      Both boards also have other identification numbers that we are not listing here.
                      X-Main is the one that sits on the RIGHT side of the TV when looking from the back while Y-Main sits on the left and is attached to a long board, called a buffer board.
                      X-Main tends to fail more than the Y-Main, but given enough time both eventually will fail; as of this writing it's harder to find and more expensive.
                      We offer repair service, exchange service (when boards are available) and DIY repair kits for both boards; repair services mean we test boards in live TV.
                      Just a note for those wlling to belive: this is one of the many cases when a properly rebuilt board is much better than a used board. If you believe that electronics age (which is easy to do if you see how many people complain from failures) then it should be easy to see why a properly done repair is better than buying a used board that still functions: all components that tend to wear out should be replaced with new ones while a used board will only have so many more thermal cycles before it fails again.
                      Lastly, it is also important to point out NS-P501q-10a may have more than one version; before making any orders or assumptions open up your TV and make sure it uses the boards the according listings are for!
                      So here are a few links in case the site allows me to post them:
                      X-Main board repair service:
                      Y-Main board repair service:
                      Hope this helps!
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        Hey there CoppellTVRepair, I see your repair videos on YouTube and I've learned a lot from them. Thanks for sharing your knowledge and I appreciate it!
                        They call me......."threadkiller"
                        • Journey11
                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                          by Journey11
                          Hi All,
                          First time posting here ... my name is Kevin but my friends call me Journey.
                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                          07-04-2024, 02:44 PM
                        • high-tech
                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                          by high-tech
                          Hello everybody, I could use some help on this one... It's got me guessing...
                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                          9. ground (PWM2) 10. 0.9 volts cycling...
                          09-15-2020, 03:39 PM
                        • beetle1303
                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                          by beetle1303
                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                          01-13-2025, 08:49 PM
                          Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                          by momaka
                          I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                          Problem:
                          Backlight cycles On and Off.
                          Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                          01-17-2019, 11:23 PM
                        • jm1234
                          9V relay temperature 40C
                          by jm1234
                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                          05-09-2024, 03:03 AM
