Samsung Plasma PN50A400C2DXZA
  • stephenhartley
    • Apr 2013
    • 21
    I recently received this 50" Samsung Plasma TV PN50A400C2DXZA for free. Currently, when I plugin the device relays clicks on then off. Pressing the power button gives me the Samsung power on sound, the TV primes then glows steadily. Audio and side panel buttons function. I can see a flashing LED on the LJ41-05309A Logic-Main Board. I have done the 3-4 jumper test on the main board with no patterns being displayed on the screen.
    Both the Y-SUS and X-Main make a slight humming sound and seemingly get warm. I understand that a digital micrometer (DMM) is really a requirement to accurately diagnose where the fault might lie; however, I was wondering if there was anything I could without purchasing a DMM?
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Samsung Plasma PN50A400C2DXZA
    Not really. The parts that will cause your symptom are far more expensive than a hobbyist grade DMM. Without being able to test voltages on a plasma, you risk spending a lot of money guessing on parts. It would be wiser to buy a cheap DMM than to just start throwing parts at the thing, hoping you luck into the right one. (In my opinion)
      Yes, you will need a good DMM on any TV repair.
      To do the 3-4 jumper test you must remove the LVDS cable from the main board. This cable goes to the control board.
      If the screen primes, it is very likely a main board issue.
      • stephenhartley
        • Apr 2013
        • 21
        To be clear, what is meant by the priming of the screen?
        My current understanding is that the screen glows quickly, goes out, then comes back on with a steady glow. Is this correct?
          Priming is the continuous, uninterrupted glowing of the screen. On newer plasmas it can be very faint, due to high contrast ratio.
          When the panel first turns on the control board will initialise it and erase any previous images or built up charge (image retention.) This may cause some flickering when first turned on and is completely normal. I've noticed Panasonic plasmas are the most discrete about this -- the screen only lightens slightly, then dims down, when first turned on, on an LG/Samsung you tend to see a few light flickers and some sparkling pixels.
          • stephenhartley
            • Apr 2013
            • 21
            Ah okay. So the TV flickers then is primed (the glowing).
            With the LVDS removed from the main board and pins 3 & 4 jumped on the control board, no test patterns are generated on the panel (still primed)
              You may have a bad control board then. Does the LED blink five times then pause for two seconds repeatedly, or is the blinking steady?
              • stephenhartley
                • Apr 2013
                • 21
                When I turn on the TV, LED1 lights up solid for like 1 second, while LED2 flashes steadily for as long as the TV is on.
                • stephenhartley
                  • Apr 2013
                  • 21
                  Here is a picture of the rear of the TV in question as well as the logic/control board.
                    I did a little research and it might be pins 1-2 for this model to do the test patterns.
                    • stephenhartley
                      • Apr 2013
                      • 21
                      No test patterns on any pin configuration.
                        OK then, one more thing to check. Along the bottom of the plasma panel there are two or three small boards. There should be a fuse, a little like this, on one:
                        http://www.newark.com/productimages/...rd/4556386.jpg
                        You will need a DMM: Measure the voltage on both ends. If it's near 0V on one end, the fuse may be failed. There is a chance this means the plasma panel is defective and repairs beyond replacing the fuse should not be attempted. If the fuse is good, it is probably the control board that is faulty. We had a user on this forum have that fuse blow, they replaced it and it worked fine again. Same symptoms.
                        • stephenhartley
                          • Apr 2013
                          • 21
                          Wild this DMM by craftsman be suitable to correctly diagnose the fault with my TV?
                          the DMM in question
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            the DMM in question
                            Yes--That'll do.
                            Its a little basic on the Ohms functions, but will be fine for what you need
                            TELEFIX
                            • stephenhartley
                              • Apr 2013
                              • 21
                              Okay. I purchased the aforementioned DMM. Where do I begin? I have never used a DMM before.
                              • stephenhartley
                                • Apr 2013
                                • 21
                                That small fuse doesn't cause the meter to beep, reads "1". All other fuses are okay, DMM beeps and I get a "0" reading.
                                • stephenhartley
                                  • Apr 2013
                                  • 21
                                  Also, what would cause this fuse to blow? Y-SUS Failure?
                                  • stephenhartley
                                    • Apr 2013
                                    • 21
                                    So, I decided to inspect those buffer boards closer, in particular, one stood out: PCB number LJ41-05512A has something that looked as though it could be burned, it's almost as if the solder is gone. Anyway, here are some photos:
                                    • stephenhartley
                                      • Apr 2013
                                      • 21
                                      Bumping for opinions, advice. Thank you!
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        It looks like the capacitor burned up. You should check the resistance of the capacitor as it may be shorted. If your fuse is before this device, it could be what caused it to blow.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
