hello down image? Blue LED tv cuts start ok, I'm watching the alim no inflated condos I have my 24v and 12v, I have redo the welds on the map inverters fuse ok, I saw on the site tested inverters 1/8 - 5/4 j I find 4.70k modeled TUCSON TNT 4208FHD please thank you [img] http://img92.xooimage.com/files/8/c/...22-3afbb45.jpg [/ img] [img] http:/ / img93.xooimage.com/files/4/3/1/imgp1923-3afbb8d.jpg [/ img] [img] http://img92.xooimage.com/files/8/c/...22-3afbb45.jpg [/ img]
yes the tv turns off backlight flash on startup sound???? j ais taken inverter 24.41v I tried removing the cable on the inverter power supply, the power supply is not cut please thank you
hello, I return to my lcd because I still have the same problem, I change a transformer t the first card that was hs and inverter transformer
model (4023Q), always the same failure, I buy another card but the problem remains the same, then how? I still look at my power supply, my 24 volt ok
emerge, why when I plug in the power supply inverter slave is not cut and when I plug the card master card buy on ebay 30euros the power supply is cut. thank you
