Toshiba 42HL67US blows fuses.
Re: Toshiba 42HL67US blows fuses.
.8 both ways? Definitely something badly shorted there.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yep. So, the way to find the short is to isolate parts of the circuit until the short disappears.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
if so there seem to be like 6 on here. 3 in one location all on 1 heat sink.. and 3 each on their own heat sink?
ok i am trying to test what i think are mosfets..they have 3 terminals.. but somewhere on here i read they should have a "Q" mark on board.
all my "mosfets" seed to start with a "D". does that seem right?Last edited by wickedwill; 04-02-2013, 12:50 PM.Comment
MOSFETs will almost always be labelled "Q", and will be on the primary side. The primary side is the part connected to the mains connector and is indicated by a thick line on the bounds usually.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Those are the secondary side diodes -- no need to check them yet.
The primary is to the right of the white line snaking around the board.
https://www.badcaps.net/forum/attach...6&d=1364930007Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Isn't the 200V/560u cap in this image bulged?
https://www.badcaps.net/forum/attach...7&d=1364930007
That may be the fault! (A bulged high voltage cap can short.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes that capacitor does look a bit rounded to me now that you have better eyes than me and i got the board in front of me ( that what i am lol about)
ok that capacitor is very close to fuse also.. how in the world would i check that or remove as i am aware that caps can shock you..Comment
Since you have a short across the bridge rectifier the cap should be safe.
Remove the cap then check the resistance across it, and also across the terminals where you removed it.
DO NOT RUN THE POWER SUPPLY WITHOUT IT!!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
would i just use the (200) ohm setting? if so
it measures 0.8 on that scaleComment
"it measures 0.8 on that scale: reading at the cap terminals off the board or at the pads on the board with the cap removed?
If at the pads of the board, then more likely to have shorted MOSFETs, the bad part is that when MOSFETs blew up, it can can take out the IC that drives the Gate circuits.
You will be doing some surface mounted components replacement.
You may want to look for new board at this point.Last edited by budm; 04-02-2013, 03:13 PM.Never stop learning
Yep, 200 ohm, as before, but it must be out of circuit. Is that out of circuit?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
"it measures 0.8 on that scale: reading at the cap terminals off the board or at the pads on the board?
will post results soonComment
got the suspected cap out
tested with black lead on the Neg term of cap and red on other
at 200ohm.. 0.8
no reading when in dc voltsComment
Very, very bad capacitor, dead shorted. Now, where the capacitor used to go, check the resistance across the two open holes.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It's probably just that cap then. The only way I can see it failing is a significant and prolonged mains over-voltage -- did you have an open neutral failure or power surge recently? If the TV got 230V (325V rectified) instead of 115V (162V rectified) then the cap would blow up very quickly. Hopefully it did not turn on and cause damage to the rest, but it looks like the damage is just at that cap.
Measure the dimensions of the capacitor and tell us so we can help you select a replacement. Replacement will hopefully fix TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
this is my dads tv.. he said that what happened...
power failed.. then his generator came on.. tv worked.
when power came back and generator powered down and house power(ac?) came up tv stopped workin.. that is all i had to go by
it is 200v 560 uF and i do not have a way to measure.. but.. it is about the size of a quarter in diameter.
other number on it.. KMQ 77s108? nippon chemi? 105 degrees
found tape measure.. 2.5 cm tall NOT including legs..8.5 cm diam.Last edited by wickedwill; 04-02-2013, 05:33 PM.Comment
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
