LG 37LC55 Random Flickering and then Standby
+ More Options
Posts
  • buges
    • Jun 2008
    Hi
    My LG 37LC55 randomly starts to flicker then the flickering gets faster and then it goes in to standby. From cold (eg over night) I'll get 2 hours or so out of it, then over an other hour it will happen faster and faster until it will only stay on for about 2 minutes.
    The first thing i did was replace the Cap's on the power board (c202,c206,c210,c217,c218,c226) but it's made no difference.
    Reading around the net some say it could be the TCon board or the Inverter or the main av board.
    any ideas ?
    Re: LG 37LC55 Random Flickering and then Standby
    Look at the rear of the set while it's working, you'll see the backlight coming through the rear. Does the backlight visibly flicker when the TV starts flickering?
    • buges
      • Jun 2008
      Sorry about the late reply.
      I took off the back cover to get a better look at the light emitting from the CFL & guess what? The damn things still on after 12 hours lol, So got to be a overheating issue.
      I know the inverter has electrolytic cap's on it, so i'll start there.
      I've never done the hairdryer test before (got a ww2 Clairol Turbo thingy) any ruff guidelines on how long to heat things up before they should fail from a bad cap or dry joint?
        Typically a minute or two is enough to show up problems. Taking the cover off has probably made the TV run cooler, but it will fail eventually.
        • reessi
          ACER BM320 Monitor - Horizonal Flickering Lines After a While
          by reessi
          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
          They are black on the right and gradually fade to nothing on the far left.
          They start either after 5 mins or up to 2 hours after so annoying for testing.
          They flicker continuously very fast! With a slight pause milli-second every second.
          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
          I tested each half by removing the first the left flex from...
          06-03-2025, 09:58 AM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
        • Crystaleyes
          Samsung BN44-00259A standby question
          by Crystaleyes
          Hi all.
          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
          08-11-2023, 05:15 AM
        • DrvLikHell
          Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
          by DrvLikHell
          Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
          The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
          07-05-2024, 02:54 AM
