Samsung Plasma HP-T5054 Sound but no video
  • kevinm34232
    • May 2012
    • 1884
    Re: Samsung Plasma HP-T5054 Sound but no video
    Tom I got a replacement main board today and it didn't fix it. Of course I cannot be 100% sure the replacement board is working but do you think it's the control board then?
      I'd say it is unlikely, it's possible but without a scope to check LVDS waveforms you can't rule out the control board.
      • kevinm34232
        • May 2012
        • 1884
        OK guys got the new logic control board today and that was the problem... Put the old main board in and it also worked... Murphy's Law. Thanks Tom for narrowing it down so quickly.. You think it's that main processor on the control board with the heat sink that failed?
          Probably that processor. They also have firmware on them, which can be corrupted by a bad software update, although I can't see how it would still do test patterns... Murphy does like to mess your around!
          • nwcs
            • Dec 2015
            • 311
            • usa
            I have no video and good sound. I did some testing and I have no VS at all, VA is 63v. I checked the vs and va with cn807 thru cn810 plugged in and unplugged no difference. Customer just had the power supply rebuilt so I have to wonder if something may have killed the repair. I did check both buffer boards and they test ok. The y main has two open fuses F5700 and F5200 as well as what looks like a leaky cap but does not test bad.. I am really just learning how to repair plasma's and if I understand correctly this means the smps is bad but since there are two open fuses on the y main it must be bad too. Any help would be greatly appreciated.
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              #26
              The gunk between the blue caps is just glue.
              • nwcs
                • Dec 2015
                • 311
                • usa
                #27
                I was not looking at the glue but what looks like the dielectric oxide from under the cap that ran down the board.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Ive seen that same stain on them before not the caps just some sort of silicon samsung use also. Not much info at all, is Vs dead short on Ymain or Xmain ? If no then Psu is faulty still. Also I suggest you also tighten all screws on Ysus heatsinks and replace ALL samwha Pt 680uf 25v caps on Ymain and Xmain as well as heat sinking the buffer Ics.
                  • gl4709
                    Samsung un55cu7000d with backlight and sound No Video / Picture
                    by gl4709
                    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                    01-23-2025, 06:21 PM
                  • Max514
                    Samsung UN55H8000 sound but no backlight no video
                    by Max514
                    Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                    The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                    I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                    • Unplugging the main board cable at the power supply >>> backlights came on.
                    • BLU_ON signal from the
                    04-14-2022, 10:34 AM
                    09-07-2024, 05:50 AM
                  • alro7779
                    Samsung UN55MU6103F video problem; has colored stripes on the display
                    by alro7779
                    Hello, everyone!
                    A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                    09-27-2025, 11:29 PM
                  • soeren
                    A2442 - No sound over internal speakers and no video playback
                    by soeren
                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                    All happened after the battery ran out of power overall several days when I was on vacation.
                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                    07-26-2024, 01:24 AM
