Another Samsung HP-T5064, Good Sound, No Picture
    Re: Another Samsung HP-T5064, Good Sound, No Picture
    That's in circuit right?
    • johnboy1313
      • Nov 2012
      • 1959
      Yeah.
        You have your answer. The circuit will be likely different for each, resulting in different readings.
        • johnboy1313
          • Nov 2012
          • 1959
          I've got the scope. Where do I take the waveform from?
          • johnboy1313
            • Nov 2012
            • 1959
            YSUS waveform
            https://www.youtube.com/watch?v=hB0mf4-gywA
            • johnboy1313
              • Nov 2012
              • 1959
              XSUS waveform
              https://www.youtube.com/watch?v=9auaXYXJmR4
                Ugh... that Y-main wave looks really poor. X-main looks ok.
                Main thing I don't like about the Y-main wave is that there's no ramp down portion and the ramp up is very distorted. There may be a short and the board is in protect mode. Is an LED lit near the Y-main to control board connector?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Yes
                    This indicates the board is in protect mode and is limiting the output. There is probably a short on VSCAN or VSET; check both -- those fets you tested earlier can sometimes cause this.
                    Was that probing at 10X? Looks like only 30Vp-p to me?
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Yes the probe was at 10X. I'll pull ysus again and have a look at it.
                        Also, try with both buffer boards disconnected.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          The Y test point is on the upper buffer. I don't know where to take the waveform from if I disconnect the buffers.
                            Here.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Ysus waveform with buffers removed
                                https://www.youtube.com/watch?v=4T-rlsz3ztQ
                                  Can we get a picture with the timebase at a slower rate, around 2ms/div and 20ms/div, so I can see several fields of the sustain process? Try setting trigger to LINE to get a relatively stable trigger.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    https://www.youtube.com/watch?v=ONnGljByC7Y
                                      OK, so the only faults appear to be the Vset ramp is stunted and the -Vsc ramp is gone/missing completely. I'd start looking at those Kxxxx FETs as well as the other devices; also, check any test points of those voltages and compare to panel sticker.
                                      For reference, you should see something like this (except there will be more than one Vs pulse and most newer sustains combine the function of -Vy and -Vsetdown into -Vsc.)
                                      http://ars.els-cdn.com/content/image...000735-gr1.gif
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        I haven't been able to find any test points for Vset, Vsc, Ve, etc...
                                          See here for potential test points.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
