Fixed insignia 47 that had no pic with tcon. now right at power on the on screen display says powering on brightly with blue box then after 3 to 4 seconds it dims and the blue box dims. is this normal , tv seems pretty bright but did i miss something i have multiple red blinks turning off on the indicator light.
insignia 47 lcd on screen display dims after turn on is this normal?
Tags: None
Re: insignia 47 lcd on screen display dims after turn on is this normal?
It's probably normal -- a dynamic contrast adjustment to minimise the black level glow.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by fauzanmintI have several chromebook laptops, the problem is that the battery is damaged. I tried to buy 1 and I tried on all off units can turn on normaally. This means the Chromebook can't turn on without a normal battery.
is there a way to turn on a chromebook without a battery with bios or hardware modifications?10-12-2024, 02:36 AM - Loading...
