Samsung HP-R4252 pink/blue lines, coax okay after 6 min
  • wittwerj
    • Mar 2013
    • usa
    Hello, this is my first time posting here. I found this site via a link to tom66's outstanding guide on troubleshooting plasma tv's.
    One day pink and blue vertical and horizontal lines started appearing on the screen for all inputs. After a few weeks it got so bad that I couldn't see any picture at all, except for coaxial inputs. Now if I wait about 6 minutes, and press a button that brings up a menu (like the guide) the lines get erased and the picture is great until the TV is turned off. This doesn't work for any other input.
    Here is a video of the problem, and it going away after 6 minutes and pressing the guide button:
    http://www.youtube.com/watch?v=o4djFzrtVII
    I would really appreciate some advice from the forum on what might be the problem.
    Thanks in advance,
    Joe
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Anonmis
    Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
    by Anonmis
    Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
    The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
    12-01-2023, 04:31 PM
    Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
    This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
    09-06-2024, 09:30 PM
  • jimjoe123
    LCD TV Green/Pink screen problem
    by jimjoe123
    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
    Then each time...
    02-23-2020, 01:29 AM
  • Stanley1843
    Screen Display Vertical Multicolor Lines
    by Stanley1843
    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
    06-29-2024, 11:54 AM
