Panasonic TH-50PZ80U, powers up, no picture, no sound
  • larryregas
    • Nov 2014
    Re: Panasonic TH-50PZ80U, powers up, no picture, no sound
    Should I replace both the capacitors on both the MC201 and MC301?
    • tw2005
      • Oct 2011
      • 6458
      Might as well of course can't be sure this will fix it but I have had the 2 blinker and after reflowing the cap it worked for a month then quit, did the caps and all good. Never had any freeze spray so it was a punt but the fact it was intermittent then working then quit I was confident. Could be the IC but ry the cap first. i bought a kit and never used the IC.
      • smoa
        Hello. I have a Panasonic TH-50PZ80U as well. 4 weeks ago I had no video for about 30 minutes, but then, everything started to work fine again.
        Today I am watching a show on the unit and I loose the image. The unit is still powered on and primed. Remote control access all works including power, vol, menus, etc...
        I was using HDMI input but tried component and composite, with same result. I tried Panasonic plasma D board test Tom had posted but no pattern appeared.
        Any ideas for next steps if D board test fails? Could I have a loose LVDS Cable?
        Thanks.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • mar1in
          Panasonic TH-55AS670A no picture no sound
          by mar1in
          I've got this Panasonic TV here with the following symptoms:
          * Standby Light is solid RED
          * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
          * After a couple of seconds, LED is solid GREEN and without picture or sound.
          I've tried a couple of things before tearing it apart:
          * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
          * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
          09-10-2023, 11:10 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
