50in hitachi plasma tv 50pd690dta power issue
  • Scurvypirate
    • Mar 2013
    • 5
    Hey there
    So new to this forum and a little out of my field ha. I typically fix much smaller electronics (phones) as I run a iphone repair biz. I have recently acquired a 50 in hitachi plasma tv that showed display problems.
    I have since found from scouring the web and these forums that the lower sdr buffer has gone bad and I have parts on order. I know that this was an issue because as soon I remove the faulty part the upper portion of the screen displayed.
    This leads me to my second issue. When plugged into power. The red power light comes on. Upon clicking the power button (on TV set and on remote), the tv clicks three times ( third click I believe to be the cooling fan attempting to start as it twitches but does not turn on), followed by two more clicks about 3-5 seconds later. During first three clicks. The power button switches from the red indicator to green (blue) and does not appear to flash a sequence code. Followed but returning to red light when the second 2 clicks happen.
    Now when powering up, grey lines appear on the upper portion of the tv, so apparently that means something that I can't remember ha. Maybe that the yseus board is ok?
    So what am I asking with this long post?
    So beside the lower buffer? What may need replaced, I have seen stuff from the main power board, ac plug, to simply playing with the ospocuplers?(or however it is spelled ha) essentially to bypass some part of the ac power.
    Also, since the fan does not seem to start, only slightly jerk during power, will that need replaced?
    I can post photos tomorrow if needed.
    Let me know if I missed any info that may be relevant or useful.
    Cheers
    Re: 50in hitachi plasma tv 50pd690dta power issue
    You should try with the Y-sus disconnected, does it behave differently?
    • Scurvypirate
      • Mar 2013
      • 5
      Ill give it a try tomorrow after work as its getting late here ha. Thanks for the fast reply. Ill keep you posted.
      • Scurvypirate
        • Mar 2013
        • 5
        Hey Tom.
        So disconnected the ysus board, low and behold the problem vanished.
        So what does this mean? Does the board also need replaced?
          It means you have a bad/shorted y-sus, which is a very common issue. The y-sus are very expensive, usually, so you have to fix it at the component level.
          • Scurvypirate
            • Mar 2013
            • 5
            So think it's easy to explain how to start going about it? I've got soldering equipment and such plus I can most likely get all the other stuff from the local elecy shop.
            Other wise may have to find out if the local old tv shops have any old hitachi plasmas sitting around I can scavenge.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              whats the part number on the y-sus board?
                I've never repaired one like this myself, so I'm not sure how to fix it. I'd suggest testing for shorted transistors etc.
                • Scurvypirate
                  • Mar 2013
                  • 5
                  Part number is ND60200-0046
                  • MDY94
                    Hitachi 50HK6100U display issue
                    by MDY94
                    I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                    12-18-2024, 12:31 PM
                  • lp20th
                    Samsung Plasma TV Power Supply Issue
                    by lp20th
                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                    11-28-2023, 10:28 AM
                  • navagator
                    Hitachi 57F710E Power Issue
                    by navagator
                    I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
                    I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
                    11-09-2023, 06:05 PM
                  • Cooperr
                    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                    by Cooperr
                    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                    10-21-2025, 01:11 PM
                  • celiabrown
                    Issue with Plasma Philips 37inch chassis FTL2.1
                    by celiabrown
                    Hello guys,
                    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                    Can someone has any symptom like this ?
                    Thanks​
                    05-09-2024, 10:56 PM
