Samsung LN40B530P7N has a 2 vertical lines.
  • 777kmk
    • Mar 2013
    • 3
    I have a Samsung LN40B530P7N. Set has a 2 vertical (1 inch wide) red lines on the left side of screen . Also tuner does not work. HDMI is OK. I do not know what is happend but I think its after a storm . A voltage is OK.
    Somebody knows what should I do?
    Re: Samsung LN40B530P7N has a 2 vertical lines.
    Everyone in the US blames their electronics issues on storms
    In this case you have a common defect, likely it's tab bonds. It can manifest itself in a number of different ways. See these videos (not mine):
    https://www.youtube.com/watch?v=purk_SyiT44
    https://www.youtube.com/watch?v=xHst6pKLtTE
    It's possible to fix it, but quite difficult. You can break the panel doing it. Personally, my success rate is 50%, but I've only done two TVs with this issue. If you're very careful and slow, and you have a large area to work on, it is possible to fix it.
    • 777kmk
      • Mar 2013
      • 3
      Thank You very much!!!
      I did it.
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
      • polaro
        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
        by polaro
        Greetings,
        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
        08-27-2022, 08:46 AM
        09-07-2024, 05:50 AM
